Quicken to QuickBooks Conversion Tool - Computers & Internet
    Sergeant:
  • 256 Answers
Are you thinking of making the switch from your current accounting software to QuickBooks Desktop? The QuickBooks Conversion Tool makes it easier to import data, account balances and transactions.
The Conversion Tool is a free program with a straightforward set-up process that imports your data into a new QuickBooks company file. It allows you to bring lists, account balances and transactions into QuickBooks. It also allows you to customize what is imported and creates a log file of the conversion process for you to review and keep for your records.
You Might Also Like
CASE-STUDYCase Study: Organizational Transformation
Read More Please keep in mind you should always make a back-up before attempting to convert your company file.
Below are instructions for converting to QuickBooks desktop from two common software products in the marketplace.
Switching from Peachtree/Sage to QuickBooks If you are currently using Peachtree/Sage 2010 or later and switching to QuickBooks desktop version:
First, set up the data access credentials.
  1. Launch the Peachtree/ Sage application and open your company file.
  2. Go to Main Menu -> Maintain -> Users -> Setup Security and then click Data Access/Crystal Reports
  3. Click With the Following Login Information
  4. Set your password by clicking Change
  5. After the password is set, close Peachtree/Sage
Second, select your Peachtree/Sage company file.
  1. Download and install the QuickBooks Conversion Tool from the Intuit website. In order for you to use the tool, you have to Run as Administrator. Right-click the QuickBooks Conversion Tool icon and select Run as Administrator.
  2. Select Sage/Peachtree company file by clicking the Browse In the Database Name window select your company name and click OK. Enter your password and click Next.
Finally, convert your company file.
  1. Select the QuickBooks version you are converting to, browse the folder where you'd like to keep your QuickBooks file and click Next.
  2. In the new window, verify your information is accurate, and click the Convert File The conversion process will begin. It may take some time, depending on the amount of data you have. You will see the "Finished!" message once the file has been converted.
  3. Open your new QuickBooks file and verify everything was completed correctly.
    1. Run a Balance Sheet and Profit and Loss statements from both QuickBooks and Peachtree/Sage and compare - investigate any discrepancies.
    2. You can also check for any failed transactions in the log file located at C:\Users\Yourusername\My Documents\Intuit\QuickBooks ConversionTool\.
Switching from Quicken to QuickBooks If you are currently using Quicken 2011 or older and switching to QuickBooks desktop version:
  1. Download and run the QuickBooks Conversion Tool. (Use the same tool version as the QuickBooks desktop version you are converting to.) Note: If you are converting the same year of Quicken to the same year of QuickBooks, you don't need to run this tool. You will only use the tool if your QuickBooks desktop version is newer than your Quicken version.
    1. Launch the Quicken Converter and click Next.
    2. Accept terms in the license agreement, click Next and then Install.
    3. Select Launch Quicken Converter and click Finish.
    4. In the pop-up window, select the first option, "I am transferring data from Quicken for Windows," and click Get Started.
    5. Select option "Open a data file located on this computer" and browse for your file by clicking the Select File button, clicking Convert and OK.
    6. Click Save to save your updated Quicken file. Then click Exit.Your Quicken.QDF file is now upgraded.
  2. Next, launch your QuickBooks Desktop.
  3. Go to File -> Utilities -> Convert, select From Quicken. Then, select the Quicken .QDF file you are converting. (Your upgraded file should be located on your desktop in a folder named Q12Files, Q13Files, Q14Files or Q15Files.)
  4. Follow the QuickBooks prompts to convert your file.
Please contact me or another of Kaufman Rossin's QuickBooks Certified ProAdvisors for help with converting to QuickBooks.
Posted on Jan 21, 2020
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 449 Answers
SOURCE: I want to download my
hi!!!
what is a quickbook?
Posted on Nov 19, 2008
Download Quicken Mac 2007
for Download QuickBooks Mac 2007 Go to site mention below and click on the tab QuickBooks 2007 > click on Mac 2007 and your filw downloading http://support.quickbooks.intuit.com/support/Static/INF12417.html
and if need any help installing after you download then get some guidance follow http://www.techsupportquickbooks.com/intuit/ .
Jan 03, 2014 | Intuit Quicken Mac 2007: Mac
How do I change the closing date in order to condense the data in Quickbooks pro 2006 for mac?
Quickboks for Mac is a budget and accounting software programmag-glass_10x10.gif released by Intuit (the makers of Quicken). While Quicken is intended for home users, Quickbooks is aimed at the business sector. With Intuit's Quickbooks software, business owners can create invoices, send bills and manage general business accounting issues. Knowing how to use Quickbooks can save you money so you don't have to hire an accountant. Investigate ways to learn Quickbooks for a Mac so you can start managing your small business efficiently.
  • Install the Quickbooks software on your Mac computer. Insert the Quickbooks disc and wait for the disc image to appear on your desktop. Double-click the icon to launch the Quickbooks installer. Follow the screen prompts to install the accounting software. Restart your Mac.
  • Step 2Click the "Help" button in the top menu button of the Mac OS X screen. Click "Quickbooks Help." Read the introduction for a basic start to learning how to use Quickbooks. The help file contains all essential information to start using the basic features of the accounting software.
  • Step 3Register a free online account at the Intuit Community for Quickbooks (see Resources). Intuit posts various guides and web seminars on using various advanced Quickbooks features, such as managing payroll or creating shipping logs. Scan the page for tasks that you are unfamiliar with and click a web seminar to start learning how to use Quickbooks.
  • Aug 03, 2010 | Intuit QuickBooks® Pro 2006 Full Version...
    Quicken premier 2009 hangs when I try to open it. Using Windows Vista.
    I am thinking that perhaps you need to update your driver for this. You can download the driver you need from the link below. Please follow the instructions.
    http://support.intuit.ca/quickbooks/en-ca/kb/update/update-quickbooks-to-new-product-update/Update_manual2009.html
    Dec 31, 2009 | Intuit Quicken Premier 2009 for PC
    I just installed Quicken Starter 2009 for my wife's accounts. In the process I lost my own Quicken 2008 on the computer. I want both of them. What can i do to show both icons
    Quicken Starter can coexist with QuickBooks, but not other versions of Quicken. Quicken Starter is intended for customers who do not have any version of Quicken already installed.
    Apr 09, 2009 | Computers & Internet
    Re: PIXMAMP600 I am having trouble in some instances where I get a message on the computer that my printer is off-line. I am able to print other things without a problem. When I try to print a Quicken...
    I am not too familiar with Quicken as I use QuickBooks, but if I am right Quicken uses a printer service like Microsoft Word and QuickBooks does.
    Look in the Printer Folder in Control Panel and look to see if a Quicken printer icon is displayed, if there is one, right click the icon and check the properties to make sure your printer and not Quicken is the default printer. I have actually deleted the Word, Quickbooks and Acrobat Reader printers in the past with no problems.
    You could also check the Options in File. Open Quicken and in the top left corner click File, check to see if there is an Options tab or any thing regarding the printer to make sure your printer is the default printer and not Quicken.
    Oct 03, 2008 | Office Equipment & Supplies
    Quickbooks & Quicken Support Number Call 1-8O5-225-669O We are 24 Hour Available Call Now
    That version of QuickBooks is much too old to handle a Quicken 5 file. You will need a later version of QuickBooks.
    Jan 10, 2008 | Intuit Quicken Deluxe 99 for Windows...
    Computers & Internet Logo
    Ekse
    Marvin
    Marvin
