Question about Cameras
What is coolpix 8800 system error 2 and how do you fix it?
Posted by Scott Gilley on
4 Related Answers
Anonymous
  • 81 Answers
SOURCE: I have a Nikon Coolpix 8800 with a "System Error 2"
Check the memory card. It's probably damaged. If not it should be a software error, and you have to take it to the dealer where you purchased it from
Posted on Apr 06, 2010
lock123
Andrea Lock
  • 6831 Answers
SOURCE: nikon coolpix 8800 system error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 21, 2010
Leon Robinson
  • 747 Answers
SOURCE: I have inherited a Nikon Coolpix 8800. After I
unplug battery for a few min. and put back in.
Posted on Feb 14, 2011
Anonymous
  • 5 Answers
SOURCE: I got message "system error
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
Posted on Mar 05, 2011
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
