Question about Watches
I purchased a apple watch 2nd hand (off offer up) for a Christmas present and it says it has a locked. what do I do?
Posted by Tina M Helbig on
Bahi-eldin Yaser
    Problem Solver:
  • 11 Answers
You should contact the previous owner, it seems like it was stolen
Posted on Mar 19, 2020
3answers
Apple watch is locked with activation lock
May be your subscription got expired try to visit Apple center.
Jan 24, 2016 • Apple Watch
1helpful
I have a Timex Expedition watch that I purchased on July 2, 2010. The calendar function does not keep an accurate date. It will jump a number of days such as jumping from the 2nd to the 15th. Is this a...
Yes it is a warranty situation, it clearly has a cog wheel issue and needs to be rectified. It is sticking or there a broken part inside the watch. It should be returned to the place of purchase, and they might offer a exchange which would be better.
1helpful
My Stauer Atomic won't stay connected to time signal
These watches only need to see a signal several times a day, not necessarily continuously.
If it keeps good time, don't worry about it.
Jan 05, 2010 • Watches
1helpful
How to adjust alarms
moz-screenshot.jpgSetting the alarm:
1. Pull the crown to the 2nd "click" (the possition you adjust the time) (Carefull: The seconds hand has to be on "12")
2. Press repeatedly button "B" to set ALARM hands to the time indicated by the main time hands (The ALARM hands move quickly if button B is kept pressed)
3. Push the crown to normal possition
4. Pull the crown to the 1st "click".
5. Press repeatedly button "B" to set the desired alarm time. (The ALARM hands move quickly if button B is kept pressed)
6. Push back the crown in to normal position.
At the designated time the alarm rings for 20 seconds, and it is automatically disengaged as it stops. To stop it manually, press button A or B.
5helpful
Changing the DAY on this analog watch.
On some analog Timex watches with a day/date window there are only two "pull-out" positions on the stem, one for changing the date and one for the time. To change the day you need to pull the stem all the way out and crank the hands through 24 hour periods until you get the day correct. Be sure that you have the correct AM/PM setting (if you are setting the watch after noon you need to advance the hands another 12 hours so that the day changes at midnight)
Sep 07, 2008 • Watches
4helpful
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 • Watches
Watches Logo
Top Watches Experts
Lisa Christine
Lisa Christine
john h
Are you a Watch Expert? Answer questions, earn points and help others
