Question about Toshiba Televison & Video
Getting initial setup off my toshiba tv now - Toshiba Televison & Video
Posted by Lia Lia on
marycalantha
  • 4 Answers
Very good, I think I found the knowledge I needed. I will see and refer some information in your post. thank you build royale
Posted on Jan 14, 2020
1 Related Answer
Toshiba 50 inch flat screen is on retail lock cant reset by remote or unplugging tv what can i do
There should be someplace in the menu that says first time setup or initial setting or something similar where it steps you through setting your TV. During that process it will ask you to choose between home or retail. Make sure you complete all the steps. If you can't find it in the menu, give me the model number and I will look it up.
Feb 21, 2015 | Toshiba Televison & Video
How to change language to English
If you're lucky it only has active powered memory, unplug the tv and click the start button a few times to discharge, plug back in and go through the initial setup.
May 10, 2014 | Toshiba 32D46 32" TV
Can you help, i have a toshiba tv (quite old, not flat screen) and i broke the remote control. I now have a [URC22S Universal Remote Controller] and I'm having a lot of trouble getting it to work
Please provide more details. What do you want to know. Setup codes? If so, check this site. Setup code list and setup proceedings to many popular brand remote controls are given.
Apr 22, 2013 | Televison & Video
My toshiba tv is stuck on initial setup menu, language selection. original remote is not working
Hi,, today i got the solution for the problem 'Tv Stuck On Language Screen"
I have Skyworth Lcd and it was stuck on Language screen 4 days back, i've tried every sigle App and Different Universal Remotes and buttons on Tv but nothing was working except a single App named "SURE UNIVERSAL REMOTE FOR TV"
i suggest if someone face this Language screen stucking problem and no buttons and remotes are working then you should download this App on your Cell phone and select your tv and you'll surely be able to restore your Tv.
Feb 10, 2013 | Toshiba 40RV525U 40 in. LCD TV
Hello, the problem with my mini toshiba nb200 is that when I on it, it shows the initial screen which says ; TOSHIBA Leading Innovation >>> Press [F2] for ...
If you are getting the Toshiba Select F2 or F12 screen the mother board has finished with POST.
Toshiba laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Feb 05, 2011 | Toshiba Satellite A205-S4617 Notebook
My wife tried to set initially install digital & analogue on my new TV set (Toshiba 32BV500B32 in) and didn't succeed. I would now like to reset the TV or get it back to the original as new settings...
Unplug the tv about a day,go into the tv Menu goto SETUP go down to resetting.Tv now should erase all the old memories setting and the resetting ensure going back to factory setting.
Dec 20, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Black box on tv screen
Sounds like "closed captioning" or other information mode has been setup on your TV, slect " Menu" on your remote and go through initial set up or options to see what has been set up change it. If there is a default option or factory setting available select that.
Dec 03, 2009 | Cars & Trucks
Getting m laptop on the tv screen
You should go to toshibas site. And download the User Manual if possible. this will usually be in Adobe Acrobat format.
Some laptops ( Not all ) have a certain key for example F7 Or F8 that when you start your laptop. you can press fn And F7 To switch between lcd and vga. or fn And F8 LCD-TV.
Alternatively is to re-install your operating system and hopefully this should put the system back to it,s factory default values.
Finally is to enter the bios setup, and change the initial display settings in there.
Hope this helps resolve your problem.
Mike.
Feb 17, 2008 | Computers & Internet
Televison & Video Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
