Question about Boating
Is there a remote oil fill tank on a 1984 vl-485 hydra sport bass boat
Posted by Darren Shafer on
2 Related Answers
Anonymous
  • 63 Answers
SOURCE: mice ate wiring
Try to trace all wires and see if the metal part is still intact. Do not turn it on or allow electricity to pass yet! If wire metal intact, get some good quality black electrical tape and carefully tape all the exposed metal. When done, test system.
To prevent problem, use moth balls, fabric softener sheets, or pine sol soaked on cloths to deter mice & rats. If possible, use old- fashion mouse or rat traps with peanut butter to kill intruders to your boat. If you agressively eliminate them, the problem will be solved, but you may have to periodically repeat the trap use.
Posted on Dec 16, 2008
Charles Hunter
  • 107 Answers
SOURCE: Outboard Motor Boat Bass Fishing Saltwater Base: 1990 yamaha 15 hp oil mix ratio...
100 - 1
Posted on Jul 21, 2010
How do you remove the seats on a Ranger 185vs 2005 model bass boat?
How To Remove Boat Seat On A Triton TR20 - YouTube
? 3:03
https://www.youtube.com/watch?v=YnJ88arVHAw
Jan 26, 2013 - Uploaded by TheWorkingFisherman
A brief walk through of how to remove the seats on a Triton TR20Bass Boat. This is useful for maintenance ...
How to Remove Seats in a Ranger Boat ' eHow
www.ehow.com > Sports & Fitness
A Ranger boat is a great way to get out on the water. With these boats you can go fishing, angling, or just plain boating. You may need to remove the seats for cleaning or repair, or to access the gas tank ... Remove the middle seat (if this is a three-seat model) first by wrapping your ... How to Replace the Seats on Bass Boats.
Ranger Boats 185 VS - BoatTEST.com
www.boattest.com/review/ranger-boats/665_185-vs
Jan 05, 2016 | Boating
1997 Nitro bass boat 640 LX. Where can I get an owner's manual?
Boat Manuals Now Available Free From Vessel Vanguard ...
www.passagemaker.com/.../boat-manuals-now-available-free-from-vesse...
Nov 14, 2013 - Boat owners are often frustrated by the diffi. ... I need complete operating manual for 2001 Nitro 175 Sport Fish ski boat. Peter Swanson April 6, .... I am looking for a Manuel for my Italian made 1997 AquaViva Frontier 6 meter cruiser. Thank you,. Jeff ... Have purchased 1989 Pro Craft Stalker 180 Bass Boat.
Aug 26, 2015 | Nitro Boating
Oil pump check
Those motors have a sensor on the oil pump drive gear that senses the oil pump drive shaft spinning. That sensor could be going out giving a false code. You can take off the oil line exit on the pump and crank the motor up for no more than a minute to check for oil flow. It won't be much at all....a dribble is all you can expect on idle. The most common problem is the oil tank on the motor itself or the sensor probe in the tank. The float can fall off giving a false signal as well. Make sure the cap and hoses are tight on the remote oil tank as the motor pressurizes the tank to push oil to the motor reservoir.
Aug 19, 2017 | Mercury Outboards - Zinc Merc Outdrive
94 200 hp evinrude ocean pro 20ft hydra sport. Can't get on a plane runs top end at 4000rpm at 23mph. New fuel pump. Replaced all filters cyl are fine and has good comp. Need help Thanks
Sounds like you have a serious drag or weight issue on the boat.
Could also be the wrong propeller for the setup.
If that is not it try cleaning carbs with seafoam and adding seafoam to fuel.
Sep 05, 2013 | RTO Oar Sockets
Boating Logo
103 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
