Question about Philips Audio Players & Recorders
Philips Classic 388 pocket recorder. Record button will not depress. Everything else working ok. Replaced batteries.
Posted by Michael Condit on
Geoff
  • 562 Answers
There is a manual here.
https://www.manualslib.com/manual/549505/Philips-Lfh0388-Pocket-Memo-388-Minicassette-Dictaphone.html
This may answer your question..
Regards
Geoff
Posted on Jan 09, 2020
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: Axim Record Button Does Not Work
Try taking off the left black rubber stripping and see if the button underneath is lined up correctly. Perhaps take a look inside to see that all the contacts are good.
This site will help with how to take off rubber part and open the Axim: http://www.gethightech.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=GHT&Category_Code=_axim_takeapart
Posted on Jun 14, 2008
Dictation Mall
  • 145 Answers
SOURCE: No recording occurs when in record mode
If the red light does not blink while you speak, then the internal microphone is bad or a wire has broken off. If it is blinking, the record playback changeover switch is bad. This part is difficult to replace. Repair cost should be around $75.
Posted on Jan 01, 2009
CosmaP
Cosma Papouis
  • 409 Answers
SOURCE: red record button will not depress to start recording
Check that you have not knocked the record tab out of the tape you are using.  Try a new tape.
Posted on May 28, 2009
Anonymous
  • 61 Answers
SOURCE: LFH 720 - Does it record?
This machine is a playback-only model. You will need a hand-held recorder using Philips mini-cassettes.
Posted on Apr 25, 2010
Anonymous
  • 61 Answers
SOURCE: I have a Philips pocket memo 381 that lets out a
This is the end-of-tape signal. Try turning the cassette over. If this does'nt work then there is no tape drive due to the belt coming loose or breaking.
Posted on May 20, 2010
DVR will not record to hard drive
I did a (General Settings) RESET. Then I erased all programs on the HDD. Presto - it now records to the HDD a-ok.
Phillips Pocket Memo 381 The button you press in when recording will not press in! Any ideas tThe machine plays back tapes OK
You cannot push it in without a recordable tape in the unit. The mini cassette tapes have a removable erase prevention tab on each side in the front. If removed, you cannot push record. Try another tape. Otherwise the recorder needs repair.
2helpful
I have a Philips pocket memo 381 that lets out a loud bleep when trying to record on it. Batteries have been changed twice this makes no difference.
2helpful
HP iPaq 110 CLassic Pocket PC freezes, it won't booth to windows..need help!!!!!!
I suppose your device entered this state after a reset following an installation of some 3rd party applicaton. Anyway, I'm afraid you'll have to hard reset your device to get rid of it. You'll loose all programs you have installed, as well as you personal data, but I can't see any other way to try to solve your problem. To perform a hard, press and hold three buttons: the 'windows', the 'ok' (both on both sides of the D-pad) and the record (below the reset pin, on the right of the device) buttons, and, at the same time, briefly press the reset pin with the stylus pen. Release the buttons when you see a green message stating 'CLEAN BOOT' on the screen.
Hope it works for you.
Cheers! Carlos
2helpful
I have an old Philips Professional Pocket Memo 398 but have lost the manual. How do I wipe the cassette?
At the end of the recorded part of the tape, hold in the RECORD button and pull the 4-way slider down into
REWIND position. Hold both until tape is fully re-wound.
1helpful
Red record button will not depress to start recording
1helpful
Disable the record button
Tap Start --> Programs --> My Settings, tap Wakeup Icon, remove the check mark from "Recorder Button", and tap "OK". The record button will not work when the MobilePro P300 is off.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
