Question about Home Security
I have no clue what I'm doing. I got two cameras wireless 63843. No monitor. No dvr Is there a way I can set them up to just view them live?
Posted by Miranda Wagoner... on
  • Miranda Wagoner Hoffner
    A cobra wireless 63843 and I bought it third party just the cameras alone..no manual..no monitor ...no dvr
Jim Hicks
    Master:
  • 661 Answers
I don't know. suggest you visit retail shop with cameras and ask what else you need or if you can view on cell
telephone.
Posted on Jan 09, 2020
4 Related Answers
Anonymous
  • 293 Answers
SOURCE: Internet Video Security Camera
Hi...there,
It's seems you got a settings problems. Read your manual again and go over step by step...see which settings you are missed. Make sure the cam are turn on...before you can remote view it.
Posted on Dec 01, 2008
Anonymous
SOURCE: cannot view replay
here is the manual of your clover cdr4170 dvr.
www.cctvwa.com/SUPPORT/DVR-Black4LightManual.pdf
Posted on Mar 10, 2009
  • 102366 Answers
SOURCE: how do I switch from a view finder to a lcd monitor on my canon rebel xs
Set the shooting mode to a Creative Zone mode before selecting Live View function settings in the menu. Live View shooting does not work in the Basic Zone modes.
Posted on Dec 27, 2011
solver2010
  • 923 Answers
SOURCE: i have an eight camera dvr but only have four cameras set up how can i set it so i only view those four
Brand name? Model? Camera types?
Posted on Apr 22, 2017
Will a HP 1740 monitor work?
you may choose another resolution in live monitor in DVR setting
Jan 21, 2016 | Zmodo 8 Channel H.264 Surveillance...
Outdoor Digital Wireless 2 CCTV camera System 7" LCD monitor DVR Record to SD TF but recorded playback poor what can I do please I am 81
Try recording in a higher quality than standard and see 2hatcthe results are.some of those are low resolution cameras and you won't get a wonderful image out of them.
Jun 28, 2015 | OUTDOOR Home Security
It tells me I cannot access the dvr at the shop to get live view. How do I fix this problem?
Check the connection from the DVR to the router. You may need to reset the router.
Oct 14, 2014 | Home Security
Cannot view cameras live
Make sure your monitor is pluged into the input that is labeled Main Monitor or the VGA . it cant be pluged into the spot monitors .
Its the one on the bottom left . you probebly have it pluged into the call monitor output.
Apr 16, 2014 | EverFocus Ecor264-9x1/2t Dvr Digital Video...
Lorex troubleshooting
The most common reason for loss of camera remote video is an intermittent cable connection between camera and DVR. Try monitoring with a VGA monitor, or TV with analog VGA input also to see if that is the case. Gently move the cables around that run from the cameras to the DVR while observing the multiple cameras showing on the monitor. Some remote viewing software has trouble restoring camera assignments after brief loss of camera signal.
Sep 28, 2017 | Home Security
How do I switch from a view finder to a lcd monitor on my canon rebel xs
Dec 25, 2011 | Canon EOS Rebel XSi Digital Camera
How do I switch from the view finder to the lcd monitor on my canon rebel xsi
You must be in P, Tv, Av, M, or the A-DEP modes.
Enable Live View in the camera’s Menu.
On the second set-up menu screen go to
“Live View function settings” then "Live View Shoot"-> enable.
After this all you need to do is press the Set button.
Mar 10, 2010 | Canon EOS Rebel XSi Digital Camera
What should the securicam setting be, to view remotely for the dcs 5220 wireless camera
Wireless camera security systems are available at many stores such as Wal-mart, Fry's and Best Buymag-glass_10x10.gif. These systems can be used to monitor your home and possessions while away. This article will show how to set up such a system.
  1. Step 1 Decide what you want to see on your security system. Front doors, back doors and driveways are popular choices. Other choices may include living rooms, hallways and garages.
  2. Step 2 Wireless cameras are not completely wireless. They still need a wire for power. Most systems come with plug in adapter to power each camera. Most power wires are 4 to 6 feet long. The location of your cameras should be close to power outlets. Professional installers may run electrical wire inside walls and conceal the power outlets and adapters in junction boxes.
  3. Step 3 Each camera will need to be set to its own channel. Common channels for such systems are labeled A through D or 1 through 4. Drill holes into walls and mount the cameras with screws.
  4. Step 4 The wireless camera receiver will be positioned next to the television. Connect the receiver to the television using a cable that has a yellow, red and white connector on each end. Some systems may have an "S-video" connector and cable to connect it to the television. The receiver will also be powered by a plug in wall adapter. Connect it to the receiver and plug it into the wall.
  5. Step 5 Set the receiver to channel A or 1 and turn on the television. The channel of the television may need to be set to Game, Video In or some other name designating the input jacks used. Consult your television for more information.
  6. Step 6 The view from the camera that is set to channel A or 1 should be visible on the TV screen. Tilt the camera if needed to get the view you desire. Set the receiver to channel B or 2 and repeat with the camera that is set to B or 2. Repeat with the remaining 2 cameras.
  7. Step 7 More advanced users may connect the receiver to a VCR, DVR or computer. Digital video capture devices can be used to connect the receiver to the computer. Using video capture software, the video from the cameras can be broadcast on the internet using software such as Yawcam or WebcamXP. HomeCamera.com can also be used to monitor your cameras on the internet.
Nov 14, 2009 | D-Link DCS-5220 Network Camera
Page chaging
This DVR dose not support that...You can either see one camera full screen or see all 4 in a quad screen depending on how many cameras you have and how may of them are enabled.
If the Preview feature in the Camera menu is On, you can view live video on the monitor.
Video is displayed full-screen only if one camera is turned on. If more than one camera is
turned on, video is shown in a quad view. Sorry but its not going to be able to do what you are looking for...Pelco didn’t put that feature in their small DVR until the DX4000 series......Good Luck and let me know if this helps,
cbinny1
Apr 19, 2008 | Pelco DX1000
Cannot view replay
It has something to do with the software and hardware as well.
But not the monitor that is trouble you.
Mar 30, 2008 | Computers & Internet
Home Security Logo
90 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
