SOURCE: Dometic Rooftop RV Air conditioner
why is our dometic roof top a/c on our boat draining water back into boat. is there a way to clean the drain?
SOURCE: PROBLEM WITH DOMETIC RV ROOFTOP AIR conditioner
Check at the compressor terminals between the Red and the terminal for the overload protector to see if you are getting power to the compressor on startup.
SOURCE: How to put refrigerant in Demotic RV Rooftop Air Conditioner
You will need to add a self tapping port to the suction side of the unit. You will have to determine what the size of the pipe is and then go to a local a/c supply company and buy one. It's kind of like a self tapping supply for water but for high pressure. Hope this helps. I would also put one in on the high side as well so you don't blow the valve in the compressor if you over charge it or the system is dirty.
SOURCE: odor when air conditioner turned on
Hi, If its a smell other then electrical burning, I would say it is coming from the evaporator coil inside. Take out the filter and clean it if it is the washable type and try and clean the coil. They make coil cleaner you may be able to get at your RV dealer to do this. This is the only thing I can think of that would have any odor. Unless there is something outside it is drawing in. The system is sealed and would not emit any odors other then a hot motor. You can check up top by removing cover to check the motors and to see if any critters have crawled inside. Let me no, keep me posed on what you find and if you need more help.
Sincerely,
Shastalaker7
PS Check the indoor blower motor also, it may be getting hot and ready to fail.
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
