Question about Boating
WIRING is wrong on solenoid for Evinrude E25TELCNB, CAN YOU PLeaSe SHOW ME OR TELL ME THE RIGHT WAY?
Posted by Stephen Estrella on
I just installed a new solinoid on my 115 evinrude. Now when I connect positive cable to battery it trIes to crank what did I do wrong?
Not sure what you did wrong but maybe this might help. The solenoid is basically a light switch with a electo magnet that energizes when the key is turned on and closes the connection. If your starter comes on as soon as the battery is hooked up I would be checking to see if you don't have the wire for the key hooked up to the battery and visa versa. Only so many combos those wire can run.
Aug 12, 2018 | Evinrude / Johnson 135-150-175-200 HP...
1974 Evinrude 135 wiring diagram for starter to solenoid to battery or something like that
If the diagram is available it would be at the Evinrude website, if they even have one.
Jul 30, 2018 | Cars & Trucks
Can you direct me to an exploded diagram of the starter on my 1994 60hp even rude motor
the good thing about starter motors is they are all constructed the same so any wiring diagram of a starter / overhaul manual for starters will show how it is made and the wiring diagram of the fields , armature and solenoid
if you go google and type in ---workshop manual for evinrude 60 hp 1994 outboard engine -- you may find a pdf version to download
Feb 26, 2017 | Cars & Trucks
Hi have a 1984 evinrude 35 hp model no E35RLCRR that wont start
There should be two hot wires one from the battery and one from the switch the one from the switch check should be hot when the key is held on the start if it is the starter solenoid is bad
Dec 23, 2014 | Clymer EvinrudeJohnson Outboard Shop...
Hi i have a 1984 35 hp evinrude electric start E35RLCRR that wont start or turn over
If you are sure that all connections are clean and bright, including the battery to the ground and battery cable to the solenoid, jumper from the battery (+) to the solenoid (+). If the solenoid clicks, but motor doesn't turn over, your solenoid is bad. Try jumpering momentarily from the battery (+) to the starter (+) and that should cause the starter to rotate. If that makes your starter rotate, your solenoid is still bad. Be sure that your starter has a good ground connection
Dec 23, 2014 | Cars & Trucks
Hi I have a evinrude 60 hp It's and old motor and
should of told us how old
and then put this in the marine section
Sep 07, 2014 | Cars & Trucks
Can't get any power to my evinrude tilt and trim what am I doing wrong ?
Check fuse.try connecting trim wires from t/tilt motor direct to battery supply to see if motor is ok.t/tit solenoid could be faulty,switches could be faulty.broken wire in loom or control box
Aug 16, 2014 | Sierra International 18-6756 Marine Power...
Boating Logo
102 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
