WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is thewater valvewill stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, youmay haveselected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
Theitem to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going tourwater inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Another test u can do to check thewaterinletvalve,first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs,but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
By the way my advice is freecuzGod is good!
My admiral washer don't work on rinse cycle. It fi - inlet how2clean inletvalvewest_washer4-undefined-undefined-5.jpgt_washer4-undefined-undefined-5.jpg" alt="inlet how2clean inletvalvewest_wasMy admiral washer don't work on rinse cycle. It fi - inlet testing washerwater inlet valve-undefined-undefined-9.jpg
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
SOURCE: Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
SOURCE: Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
SOURCE: Cold water will not stop filling during rinse
My washing machine is F&P MW512, it
cannot fill up cold water properly, just drip. I need to turn on the tap for
the tub for a few second, then it properly fill. After one cycle, it happen again. Is it something wrong
with the water pressure?
