Televison & Video Logo
Levy Sims Posted on Jan 08, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg 60LN5710 LED SCHEMATICS - LG Televison & Video
Geoff
Level 3:
  • Master 562 Answers
  • Posted on Jan 09, 2020
Geoff
Master
Level 3:
Answers
562
Questions
0
Helped
179193
Points
1681
Try looking here for an answer to your problems >>>
https://www.lg.com/us/search/search-all
Regards
Geoff
LG W1934S turn on, power led shows blue light, but no display
so working on super old 2007 PC monitors. and no PC connected."? it is NOT ANY LED BACK LAMP monitor here.
came new with XP PC's.
the monitos all good to sleep mode if no PC vidoeo connected.
in the usa, even by law, (energy star)
how ever lacking a PC, the screen will show "no signal entering sleep mode"
VGA monitor.
LED = blue on, amber sleep, LED out, oFF.
NO 1080P mode allowed, (so common now) <<<< big clue here.
set the PC to 1024 x 768 (to test ) 60Hz.
using a flash light (torch) tool,.
turn on Monitor, see blue LED
point flash light to screen, see data, now, on sceen in the beam
now you now CCFL backlamps are dead. as most are this old.
Display Modes (Resolution)
640 x 350
720 x 400
640 x 480
800 x 600
832 x 624
1024 x 768
1152 x 870
1152 x 900
1280 x 1024
1440 x 900
proof BELOW. A FREE MANUAL TOO.
page 47, see 4, CCFL jacks and HV supplies here 600VDC
free service manual with full schematics and BOM
https://elektrotanya.com/lg_w1934s_flatron.pdf/download.html
in my shop I have VGA signal generator to maKE WORK EASY.
Power supply schematics for LG TV LG 55LB5550 Thank You.
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Circuit diagrams of many popular brand TVs and other devices are given.
Schematics can't be uploaded by this window.
1helpful
I have an LG 55lm4700 that has no power led and no picture, wondering what might be the issue.
it sounds like a blown capacitor in the unit somewhere.
here are some tools you are going to have to have: ohm meter,oscilloscope, signal generator, soldering equipment,
grounding equipment, diagrams, schematics, test points, layout of circuits,
I have a LP156WH2 LG display from an acer notebook and i can see the image but the led backlight does not turn on, it had a led open i replaced it for an identical one and still is not turning on, i live...
Check the supply voltage to the backlight LED's. If it's too high and thus causing the LED's to go open a new panel will just become junk when powered on, and you may have damaged the replacement panel you already tried. To check the voltage just measure it at the cable end you connect to the panel. If no voltage bad motherboard. If too high still a motherboard issue, but you might be able to regulate it with a simple solid state voltage regulator.
My tv is plugged in but won't turn on with the remote or the power button on the unit. Was working fine last time I turned it off.
Is the power LED flashing dimly? If so (or not) the likely problem is power board (marked BT-EFL32230W-A) LG part # 6871TPT303B is likely in need of replacement. There are no schematics available for this part and the part cost is around $100.00. It is rather difficult to get to this part as the entire works of this product is behind a heavy steel shield. be careful to re-attach the conductive tapes attached to this shield!
3helpful
2answers
Picture went out and power led flashing
6helpful
LG TV (LCD) power supply schematics
Service manual from SAMs does not include a schematic of the power supply board
1helpful
Got paint into speaker of LG cu720 shine
I suggest you google: Schematics for LG Shine CU720 cell phone and follow the links provided.
The answer is there. There may or may not be a cost for the Schematics.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
