SOURCE: garmin does not read scandisk 2 gb.
it might be due to the fact that you garmin cannot read AAC music format(the format itunes uses). try using windows media player to rip the CD then put the music on the card using windows media player. this should take care of your issue.
hope this helped.
please rate good.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: Compaq SR2041X does not read SDHC card
Possibly a band Reader.. one thing you can do is test to see if it reads other types of memory cards such as panasonic or kingston. If those do not work then it may be a bad card reader..
SOURCE: my Mustek dv-3500 doesn't take a 1 gb or 2 gb sd card?
If the camera will accept a 1GB card you'll be happy to know it will hold a ton of images (verses your 128MB). Yes - you would format the SD card in your camera. You should find the instructions in your manual or poking around in the menu.
SOURCE: When I inserted SD Card
It might be to do with the fact that your camera doesn't accept a SD HC (High Capacity) card. Older cameras can't read/write to that format...
SOURCE: I got an Aluratek air ebook reader,I have a bunch
Checked on there web site says they can handle 32 GB cards. But you said something interesting you said you have SDHC cards, which are NOT the same as hd cards. So while a device may take one cared they will not take another card.
Not sure what the difference is but different they are. Try a larger SD card if you can find one, probably find the SD format will work fine but SDHC not at all.
Hope this helps
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
