Question about Measuring Tools & Sensors
Model: CA87092--wind is not being displayed on weather station Why?
Posted by Myrtle Baillie on
ray gallant
    Top Expert:
  • Measuring To... Master
  • 68,556 Answers
Probably needs new batteries ,
Posted on Jan 08, 2020
1 Related Answer
Tom Chichester
  • 55983 Answers
SOURCE: On Che celestron weather station which end of needle shows the. Wind direction
The smaller end
Posted on Oct 09, 2015
New la crosse technology wind speed weather station model # CA87092 set up.wind speed and outdoor temperature showed until this morning.new batteries used yesterday in setup. what is the problem?
The instructions for your station call for a specific set up procedure. Batteries should be installed in the transmitter first with time allowed for it to initialize and begin sending data. After installing batteries in the receiver, you should see wind speed and temperature displayed. BUT, here in the real world I have a Lacrosse receiver currently displaying a balmy 67 degrees inside and a not-so-balmy - - outside. I believe the alkaline batteries used in the transmitter lose efficiency or freeze at low temperatures. Warmer weather restores the outside temperature display.
Jan 05, 2017 | La Crosse Measuring Tools & Sensors
ACCU-TEMP WEATHER STATION, MODEL IW007A. IS THERE A MANUAL FOR THIS DEVICE?
Let's find out. Google (ACCU-TEMP)(IW007A)(manual) without parens.
Oct 27, 2016 | Measuring Tools & Sensors
Why does my wind speed not work
put a new battery in the wind generator outdoors .
Oct 08, 2015 | Celestron Deluxe Weather Station
Caldwell wind wizard how do i change it to read in mph
Press the SET button to sequence the units to MPH like you would a digital watch/clock
Jan 21, 2014 | Caldwell Wind Wizard
The receiver display on a brand new dr.tech 1070 weather station will not come on after battery installation
My solution would to be to throw it on the ground and stomp it into dust. Mine doesn't work either and there is NO support. Total junk.
May 02, 2012 | Measuring Tools & Sensors
Download Digitech Weather station XC0346 Manual
To set station Hold SET key down for 3 secs. Press SET key to select setting in this sequence. 1. Time Zone 2. 12/24hr format 3.Manual time setting HR/Min. 4. Calendar setting y/mm/dd 5.Temp display C or F 6.Air pressure display hPa or inHg 7.Relative pressure setting from 919.0hPa-1080.0hPa 8 Pressure threshold (sensitivity)Default 2 9.Storm threshold Default 4 10.Wind speed reading km/h, mph etc 11 Rainfall display in mm or inch. Use the + and History keys to adjust values (History key is - ) When replacing batteries Fit outside unit ones first then fit inside unit ones in that sequence so it can interpret the security code.
Apr 05, 2012 | Measuring Tools & Sensors
WMR928NX battery replacement
I have an Oregon WMR928NX weather station. I have replaced the alkaline batteries in the wind and rain sensors. These did not communicate with the main unit, so I reset both units but only the wind sensor communicates. I have checked both battery voltages on the cuircuit board and both are correct, I don't know a solution. Thanks Rob
Nov 23, 2010 | Oregon Scientific Cable Free Weather...
Measuring Tools & Sensors Logo
94 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
