Question about JVC Televison & Video
Using Firefox on a new JVC Smart TV to show content from a website on screen. TV keeps going to sleep after 5 Mins because it thinks it is not being used. is there any way of adjusting this?
Posted by David Dowey on
Geoff
  • 562 Answers
Are you using the Android version of Firefox.
If not, try using it.
Regards
Geoff
Posted on Jan 08, 2020
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: cannt get tv to change chanel
Check the mode the tv is on (Use "Source" button on remote to change modes). There are several modes to choose from.
Posted on Jul 18, 2008
bcdalai
bcdalai
  • 20 Answers
SOURCE: Flash player 10.0.12.36 is installed but not detected by appln
The problem seems to be conflict in the .dll file "NPSWF32.dll" and it's association with the Windows Registry. The registry key of the flash player for Mozilla Firefox is damaged/corrupted. So you have to uninstall Flash Player: (Follow both the steps.)
Step-1: First uninstall through ADD/REMOVE Programs from controls panel.
Step-2: Then download the Adobe Flash Player uninstaller from here. Now close both Firefox and Internet Explorer. Then run the uninstaller tool. After uninstalling, restart your PC. Now open the firefox and go to http://www.adobe.com/support/flashplayer/ to install the latest version flash player.
Remember: Whenever you are installing or uninstalling flash player you must log on to windows as Administrator to perform and troubleshoot this type of issue.
bcdalai
http://bcdalai.blogspot.com/
Posted on Jan 26, 2009
Sean Blundy
  • 289 Answers
SOURCE: I have a 32
its overheating or the lamp is bad, get some canned air and spray the inside with the air.
Posted on Sep 30, 2009
Obertelli
Obertelli
  • 3006 Answers
SOURCE: WONT START UP AFTER USING FOR 4 MINS OPEN DOOR
The oven is overheating. Ensure that all external vents on all sides are perfectly clear and that there is sufficient clearance around them as specified in the instruction manual. Also ensure that the vents inside the oven cavity are clean and clear from obstruction.
If this does not fix your problem then you probably have a failed cooling fan, this will entail removing the outer casing and testing that all fans work correctly, most microwave ovens have just one but many have two and sometimes three. A failed fan repair will require the use of a multimeter and some general electrical repair competency; if in doubt get it done professionally as some of the voltages beneath the casing of a microwave oven far exceed mains voltage and can kill you.
Labour rates for fan replacement are generally cheap as, like most jobs on any microwave oven, component replacement is usually very quick and easy for a competent person.
I hope that my posting has been of assistance to you, if so then please take a moment to rate my answer.
Posted on Jan 11, 2010
Anonymous
  • 360 Answers
SOURCE: Suddenly my wireless will not stay connected. I
Go into your "router" configuration under wireless, change the channel it operates on. It is possible some new electronic in your house or neighbor is causing signal interference on that channel causing you to drop your connection periodically.
Posted on Feb 03, 2010
I have a Hisense Smart Tv and trying to figure out if it;s bluetooth accessable
Hi there, fastest way to determine this is by using your smartphone and through settings/Bluetooth, search for available devices. If it shows up, then you're good. This all depends on whether the tv is set to 'findable'. elsewise, I would review the tv's menus settings.
Feb 02, 2018 | Hisense Televison & Video
We keep loosing our Audio on Netflix .We recently purchased a new Samsung Smart T V. Some think its the T V Model ? I didn't know U had to ask if the T V was Netflix compatible ?
I just bought a new Samsung Smart TV and they are Netflix compatible. Netflix shows up in the list of things to view along with Amazon, You Tube and the rest of the internet streaming services. I'm using a wired lan connection. If you're using wi-fi you might try a lan cable but I would thing that you would be getting picture problems along with audio problems if the lan was the problem. You can allow Samsung to connect right into your tv and they can take a look at it as well. Call the place you bought it from for an answer about the model or check your manual. You can even access Samsung and allow them to go right into your tv over the internet.
Do it before your warranty runs out! Do it now and get on to enjoying your new tv!
Nov 29, 2016 | Samsung Computers & Internet
My JVC projection tv model:AV-65WP94, when i turn it on the screen turns red and in 5 sec turns screen off but power light blinks.what do u think the problem is?
Go to JVC website for a copy of the manual. I suspect the projection lamp is bad.
http://secure.jvc.com/consumer/forms/contactsupport.jsp
Jun 07, 2015 | JVC Televison & Video
How do I make the picture big when watching Netflix on my toshiba smart tv
Netflix Phone Number
Phone Number
888-638-3549
Press 0 at each prompt.
or they call you instead
http://gethuman.com/call-back/Netflix/
Average Wait: 5 mins - 24 hours, 7 days
Phone Number
888-638-3549
Nov 29, 2014 | Netflix
I'm currently using Mozilla Firefox, when I open a new tab instead of getting a blank screen like normal I get the imesh search engine. I have uninstalled imesh from my computer but this option keeps...
Your problem can be solved simply by changing your homepage. To do that follow this steps:
1) Open Mozilla Firefox.
2) Never mind what's on the screen. Just go to Tools. Click on it and choose Options...
3) A window like this will appear:
4) Just follow the highlighted parts and click OK.
5) Restart firefox and you'll see a blank screen.
Tip:
You can also set a homepage of your preference. Just input the website name in the Homepage field and click OK.
Hope it helps.
Thanks for using Fixya!
Feb 07, 2011 | iMesh
HOW DO RESET THE HDMI INPUT? JVC , HD61Z456.
Set the remote to "TV" and 'VCR". Press the sleep timer once and "0 Minutes" will show up on the screen. Afterward, press and hold the "Display" and "Video Status" buttons simultaneously and then let go. A menu will show up on the screen, then press "#2" on the key pad. A new menu will show up on the screen, then shut the power off. I was told it could take up to 3 times for this to work. Hope this helps.
Jun 11, 2010 | JVC HD-61Z456 Television
Suddenly my wireless will not stay connected. I get online and in less then five mins. , as I try to go to a different website, nothing happens. Using firefox, will show loading then go to server timed...
Feb 03, 2010 | Gateway MX3560 Notebook
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Jan 02, 2009 | JVC LT-42X688 42 in. LCD HDTV
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
Televison & Video Logo
48 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
