Here is the website to download a user manual for your remote.
https://www.magnavox.com/en/content/7-support
Regards
Geoff
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
SOURCE: codes to program a universal remote to this device
You can try the following four digit codes:
0670, 0695, 0873, or 1919.
SOURCE: SANYO FXVR REMOTE
These remote codes seem to work for the Sanyo FXVR remote
http://www.sanyotv.com/RMT-U340A%20(ES)%200192--.pdf
SOURCE: Need Remote Code to program Sanyo TV for remote model RC24977-0
Try these (4 digit codes)
SANYO.............0049, 0097, 0110, 0004, 0268, 0012, 0108, 0180
SOURCE: need Sanyo TV code numbers
These are the codes for Sanyo TV'S for this remote. The newer TV codes are at the end so work in reverse order when inputting these codes. Thanks for using Fix Ya.
542, 589, 590, 591, 592, 609
