Question about Sansui Televison & Video
I have a Sansui VCR-DVD combo that I lost the remote for. It has all of the standard play, stop, rew, and ff buttons on the machine but the play button doesn't work and no it's not stuck.
Posted by Rachale Faulkner on
Arnie Burke
  • 6,684 Answers
Pour some rubbing alcohol into playr or on buttons..it breaks them back to life from the corrosion..use only 70% or more
Posted on Jan 07, 2020
5 Related Answers
Anonymous
  • 254 Answers
SOURCE: VCR stops playing
A couple of possibilities: the bad electronics unit might have power supply problems, optical sensor problems, or other problems with the electronics. If you have some tech savvy and a voltmeter, you could check the power supply voltages. This circuit is likely in the close vicinity of the fuse. On the output side you should see a +5 volt, +12 to 15 volt, and perhaps a -35 volt (approx). The +5 supplies the logic circuit, +12 the motors. If these voltages are missing, or way out of tolerance, you will have a dead unit. A frequent cause of problems in the supply is bad electrolytic capacitors, especially in the older units (Panasonic manufactured rigs, late '80s/early '90s). Possible values on these capacitors: 2200MFD/10V 1000MFD/16V and several others. Replacements can be supplied by MCM electronics, Mouser electronics. I use the Panansonic FC series from Digi-Key Electronics. Sensor problems: Many VCRs have the sensor opticals mounted on the main circuit board, and locate themselves in particular spots in the mechanical section. One or more sensors detect tape loaded, one each for the supply & takeup spindles. If any of these sensors (especially the supply/takeup sensors) are non-working, the logic circuit will detect an error condition, and shut down the unit or at least put it into a stop mode.
Posted on Oct 02, 2007
Anonymous
SOURCE: Need a remote control code for a Sansui TDC2075 TV/VCR/DVD combo
Contact Fox International parts at 1-800-321-6993
or Sansui troubleshooting hotline at 800-289-0980
thanks
Posted on Nov 13, 2007
Anonymous
  • 10594 Answers
SOURCE: Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
Posted on Oct 09, 2008
Bob Citizen
  • 520 Answers
SOURCE: Sansui VRDVD4000
Universal remotes rarely fully work with these type of units. Call Orion customer service 800 289 0980 to price an original remote.
Posted on Oct 22, 2008
Rod
  • 19 Answers
SOURCE: Sony SLV-N71 VCR makes a rattling sound (ff, rew)
I make no claim to being any kind of an expert techie but it sounds to me like there are one or more loose or badly worn parts inside your machine. If you haven't had a look at the innards, try that. Loose things can usually be re-secured and, sometimes, worn parts can be replaced.
Rod
[email protected]
Posted on Feb 06, 2009
Lost the remote
I'm sorry but, no you need the remote. The cheapest way to go is usually to check everyone's favorite auction site for the remote for your model number combo player. There are also some sites that specialize in "replacement remotes" but , are usually more expensive. I hope this is helpful to you. Bobya.
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
I have a Samsung VCR/DVD combo and I do not have the remote, my question is what universal remote will work, I have bought lots and they will all allow me to press play but they don't all me to sk
Codes to Samsung DVD/VCR are: 0455 0963
Buy one universal remote control, which have these set up codes for its DVD/VCR codes list. You can get this detail from the code list attached with the remote control.
Describe your Panasonic PV-D4743 DVD Player / VCR Combo Problem I DO NOT HAVE REMOTE FOR THE DVD/VCR. WILL A UNIVERSAL REMOTE SOLVE THIS? I HAVE A SHARP TV WHICH ALSO LACKS A REMOTE.
Universal remote may give you few controls like power on-off, FF, REW etc but Menu may not open.
Substitute remote for this Combo is available in Remotes.com and original remote is available in Panasonic Parts under part number LSSQ0374
Same thing goes to your Sharp tv.
Thanks.
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
I am trying to sync my sansui tv with my magnavox dvd/vcr combo. I can't figure out what channel the sansui needs to be on to play a dvd. The input button on remote is not working.
Tries buy a new remote this website have a exact or very close to the Original remotes.1-800-Remotes Factory Original.Tries channnel 3 only or 4 only functional for video equipments.
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
No remote for set-up
you should purchase a universal remote.
4helpful
Sansui VRDVD4000
1helpful
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Televison & Video Logo
Top Sansui Televison & Video Experts
 Grubhead
Grubhead
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
