SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
SOURCE: Durabrand TV 2127N
if your tv doesnt have the original remote control that is the problem,you have to find it,if you can't find it try universal remote control.i was have same problem its been solved by this way.
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
SOURCE: My Sanyo TV remote AV button has failed. Is
Why would I tell you how I fixed my problem if I have to pay you to tell me.
