SOURCE: Maytag Mod # MFI2568AEB..SER 10962398JC....Problem....all
The capacitors on the high voltage board on the back are out. You will have to replace the board.
SOURCE: need a wireing diagram for
Often the wiring diagram maybe found in the console area or under the dryer top panel. Due to regional differences in electrical code and power requirement, wiring system hence the diagram may differ. Additionally, it would also differ if you are using a 4 wire outlet or a 3 wire hookup.
At this point, perhaps your best bet would be to seek the services of a qualified professional who is very familiar with the electrical/power system of your area as well as general wiring of dryers. Should you venture a DIY, pls post back power requirements/availability whether for a 240/120 or 110/110.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
SOURCE: I have a maytag model 747g dryer. I dryer tumbles
The heating element is burnt out. Unplug the dryer. Follow the wires from the control panel. They will go to the heating element. The element is probably held in by anywhere from 2 to 6 screws. Remove the screws and you should be able to pull out the element. The element is coiled wire that heats up when power is applied. If you look closely you can probably see a break in it. To get a replacement you will need the model number which will be on a metal plate either on the back of the dryer or inside the dryer door. Take the old part with you so you can do a comparison and make sure you get the right part.
SOURCE: wires for the maytag dryer are black, yellow, blue
The red and black wires of the cord go to the outside two terminals. The white on the cord goes in the middle. The green goes to the frame. Red and Black on the cord are L1 and L2, White is Nuetral, and green is ground
