Question about Panasonic Televison & Video
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Posted on Oct 26, 2008
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
SOURCE: TV WONT TURN ON, STAND BY LIGHT FLASHING 3 TIMES CONTINUOUSLY
having problem with sony television the screen when its turn on no images found just found red color on the screen..
Posted on Feb 01, 2009
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Posted on Jun 06, 2009
Aug 07, 2016 | Panasonic Viera TX-L42B6B 106.7 cm 42"...
Apr 04, 2016 | Panasonic VIERA TX-L42E5B 42" LED TV...
Nov 08, 2013 | Panasonic TXL42S10B 42 in HDTVReady TV
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Jun 29, 2010 | Panasonic PT-44LCX65 Television
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
Apr 22, 2009 | Televison & Video
Feb 09, 2009 | Panasonic TX-26LXD1 26 in. LCD Television
Feb 01, 2009 | Panasonic TX-42PT10 42" TV
79 people viewed this question
