Mo#3616dew-15 control paned wont change time - temp unless upluge & replug is this under warranty or do i take back to wall mart?
Posted by kenneth hill on
jenifer ronan
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Asus is a broad name for manufacturing and selling of leading products such as the computer, laptop, tablet and much more.When Asus devices come across technical problems they can call on a toll-free number and gain help for fixing the problems. Connect via dialing Asus Customer Service Phone Number and gain the technicians at the doorstep. Technicians advise the user in the right direction by fixing the problems and successfully repairing and mainaging the Asus Product is our responsibility and priority.
Posted on May 29, 2020
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Cooling fan wont come on when car reaches operating temp
replace the radiator fan switch,,renew your thermostat if needed,maybe your lower radiator is still running cold ,/poss,air lock in system,,
Posted on Jul 23, 2009
Anonymous
SOURCE: Not cooling enough
I had the same problem and I discovered it was the defrost element that was shorted out which keeps the ice from building up located behind the back freezer wall.
Posted on Aug 10, 2009
Anonymous
  • 787 Answers
SOURCE: Sony Bravia KDL-52XBR9
There is a error in TV.Count how many times blinking the red light.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Posted on Nov 16, 2009
Testimonial: "I also bought the Sony KDL-52xbr9 mine did the same thing with six blinks. I sent it back to to store. "
prethi123
  • 122 Answers
SOURCE: sony ps3 will work great
i think your ps3 might be overheated due to the regular use..or you might switch on the timer in it so it switch off after some time...u can visit this site to solve the problem click hearLoading
Posted on Nov 10, 2010
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: the washer indicates with a
If you are referring to the Control Lock on a Whirlpool Duet, Kenmore Elite, or Maytag Epic series front loader, this is built-in a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
The following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more significant problem other than a simple operator control button issue (such as an operator console problem or main control board issue).
NOTE: Each one of these washers come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot if you cannot get the control panel to unlock.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Posted on May 31, 2011
Why does my sharp tv 32k-x1000 picture turn offand wont come back on unless i unplug it then replug in outlet
Main system control memory IC fault. Replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Sharp 32K-X1000 TV
Freezer and refrigerator to cold...everything is freezing on fridge side
check for a faulty thermostat that tells the board when to run or not . If it is still under warranty have a service inspection done .
Jun 13, 2013 | Whirlpool Refrigerators
My Cal Spa tub just put in a new dually motor and 6 months later my motor will turn on but just humm for 1 min motor wont turn on, if i hit the button to go on high it turns on then hit the button aga
Sounds like starter switch has failed in the motor. Since it is only 6 mo old, should be under warranty. You can wire it for high speed only and then it will start and run and keep the water warm, just a bit nosier. Possible that you can get a new switch if warranty is out, if you are up to changing it out. You will have to contact the motor manufacturer or their rep to order one.
Sep 22, 2012 | Rotary Spa Pump Dually Pump Cal Spas 110V...
I have a Panasonic plasma tv . model th-c42fd18. the tv will turn on and run for 15 teen to 20 minute ,then it shuts off and l.e.d. blinks 8 times
An 8 blink error code means that your SS board is failing. The SS board is on the right side of your set, if you are looking at it from the back. This is a very easy board to replace.
Panasonic part# TXNSS1RLTU
Jun 08, 2012 | Panasonic Televison & Video
The remote is not working the box and neither is the buttons on the front of the box
Tries Dish box uplug,replug it back by letting the box softwares to updates.The remote have not change batteries in it a few months,change the batteries and push the SAT button on the remote few times.Should be working again.
Jan 18, 2011 | DISH Network IR Remote Control
Freezer and Refrigerator Heating up
chances are the evaporator coils (behind the back freezer wall) are icing up and must be thawed out. this is from too much moisture freezing to the coils (door left open in hot weather, drain plugged, or fridge filled before letting it chill for a day empty and on). take back wall off and use warm water or a hair dryer (only until ice melts- do not overheat metal) to melt the ice. soak up excess water from under fridge, too. also check to see if the fan is working.
Jul 20, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Whirlpool Duet Washer beeps and will not allow temp change
Norma,
It's likely that this is a control board issue. Luckily you are still within your warranty period. I'd recommend contacting Whirlpool about this.
You may also try "re-booting" the CPU by unplugging the washer for a few minutes then plugging it back in.
Jun 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Temperature Control not working on LG fridge
It is an error code. The thermal fuse in the freezer section has gone. It has to be replaced. To get by in the short term, uplug the unit for 15 minutes, then plug it back in. It will run until it hits the defrost again (approx 5 hours) Part location is 401A and part number is 6615JB2005C. It is easy to change once you get the back cover off. Plug in part.
Sgt 48
Jun 07, 2008 | Refrigerators
Canon D780
try uplugging for a few seconds and replug it back to wall socket or push powersave button on control panel then try to use
Dec 12, 2007 | Canon imageCLASS D780 All-In-One Laser...
Ekse
Marvin
Marvin
