Question about Frigidaire Washing Machines
My frigidaire gallery front load washer has been beeping, turning its self on and off for over 15 hours steady . What is wrong with it?
Posted by Stacy Sullivan on
ChinthakaJ
  • 943 Answers
Maybe needs a resetting. just remove the plug for few minutes and try
Posted on Jan 07, 2020
5 Related Answers
the dr
joey shearer
  • 447 Answers
SOURCE: error code
what is the code???
Posted on Jan 05, 2008
Anonymous
  • 184 Answers
SOURCE: Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Posted on Apr 05, 2008
Anonymous
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
Anonymous
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Posted on Dec 03, 2009
rcalorisian
Randy Trent
  • 313 Answers
SOURCE: my front load washer keeps beeping even when there
Beeping is pretty vague, but here it goes. Read the very broad answer. Your answer will be in it. I hope this helps.
LOOK HERE
Posted on May 29, 2010
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My moms front loader is a frigidaire gallery series. when she tries to start a load itll bring in a lil water and then just stop. don't understand why it is doing that
Turn off the machine then unplug it for at least 5 minutes and plug it back. Turn on the washer then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it.
Jul 19, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire gallery series front load washer leaking water on side where soap dispenser is. Have had two different repair places take a look at it- replaced soap dispenser- still leaks - repair people can't...
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
May 19, 2017 | Frigidaire Gallery Supreme Series...
Cant get the oven to turn off from the cleaning setting and its just making a loud beeping sound, had to unplug.
After unplugging, allow the oven cooling down for few hours.
If the beeping restart, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 02, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Mar 26, 2009 | Frigidaire GLTF1670A Front Load Washer
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Error messages
what are other codes? i believe this could be a cold water issue. check your screens at the fill hoses
Sep 22, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Gallery front load washer won't start
Call Service and have them come out.If it's new your our under warranty!
Good work done here.
A&E Factory Service
Nation Wide
7days/24 hours
They do Frigidaire warranty work.
Thank You for asking!
Please rate my, solution solved in this fixya site!
Neil
Aug 24, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
99 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
