It says error occured.please ensureyourmedia serveris functioning properly and network connectivity is active . I have no idea what to do!
Posted by Kelly Murray on
3 Related Answers
Anonymous
SOURCE: login errors occur when trying to use new networks
log in errors problems comes on the solution is the net work ip address is not matched plz find and given correct ip address
Posted on Jun 15, 2009
Anonymous
SOURCE: IS034 Error when intalling driver software for MFC-490CW on vista
This issue is cause when the print spooler service isn't running, MFL pro installs the printer driver 1st (after paperport install) which will not wun if the service is disabled
Posted on Oct 09, 2009
jeremykeefer
Jeremy Keefer
  • 37 Answers
SOURCE: Recurring problem on TV# 2 No signal Message on TV Please ensure your media server is functioning properly and network connectivity is active
Easy - you need to ensure that your network active.
Posted on Apr 18, 2018
Why does it say communication error when i try to activate microsoft office 2007
This issue may occur if you configure your Internet connection to use a proxy server that requires authentication. In some situations, the Activation Wizard can not connect through the proxy server to an internal Microsoft server and show error message.
Alternatively, this issue may occur if your firewall software is blocking the attempt to connect to the server through your Internet connection.
To resolve this issue configure the firewall software to let the Activation Wizard connect to the Microsoft server or restart the computer in Windows Safe Mode With Networking, and then try to activate the software.
May 25, 2014 | Microsoft Office Word 2003 for PC
I have an error code in the install operation tell me how to fix it
Common PS3 Error Codes and required Network Ports.
Additional PS3 Error Codes:
80010514 - Dead BD lens.
80010516 - Dead BD lens (happens at different occasions, code above is more common).
80710092 - Connection error (usually the connection is dropped), you will be signed out of PSN.
8002AD23 - Unidentified error (cause unknown), happens in Burnout Paradise (when game starts) and sometimes SARPBC.
8002A227 - PSN account suspended.
8002A212 - error returned by the PSN servers during authentication (invalid version).
80029945 - Can't playback burn BDr movie (error in picture above)
80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3
(workarouns is to transfer files to ps3 via TVersity)
(added 24th Sept 2007)
80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card) (added 15sept2007)
80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them) (added 04-sept-2007)
80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured (added 30thAug2007)
8003041F - An error occurred during the copy operation (using media server) (added27aug2007)
80010006 - An error occurred during the start operation (added 22aug07 - corrupted folding install)
80010007 - An error occurred during the start operation (added 17aug07 - during disc swap tests)
710102 - DNS Error; No DSN server available.
8013030 - System Error due to failed update download
80010001 - Major Error , Game ability stopped
80010017 - Can't start Blu-ray Game
80010510 - Will not play hard drive games - Cause unknown
80010516 - An error occured during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again
80029023 - Exchanging Key Information exchange has timed out
80029024 - "Cannot Obtain an IP address".
80029564 - Downloaded Game will not install - Cause unknown
80030920 - An error occurred during the copy operation. The file may be corrupt or there isnt enough memory. Try copying data from original source.
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Pre
80031601 - Error Creating Account
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are
80410418 - DNS Error
80710016 - Playstation Network is down.
80710092 - "An error has occured. you've been signed out from the ps network" -(connection dropped?
80710101 - Conneciton error
80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out. press the x button to repair and restore default"
80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
8001050D - An error occured during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again
80028EA5 - Unknown?? User cannot connect to PS3 network. Sony told the user to send the machine in.
80028ea6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 mintues, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sycn.
Reconnect your power cable and flip the back swtich up again. Then make a new network connnection.
80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automactic,
80028f17 - Ps2 disc Boot Error , An error occured during the start operation; Ps2 game swapped using the eject function and then play pressed quickly -Backup ps2 game inserted again
80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).
80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it
80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error
80029C68 - Corrupt data usually on external device
8002A10D - Unable to Add friend in XMB
8002A4A6 - Cannot load game to play online
8002A515 - Error Signing in
8002A548 - Unable to remain logged in - either to game or server
8002A705 - Unable to connect to server/host. Check router port configuration.
8002a71a - Possible NAT Error , Can log onto Game Server but can't join game and can't host game
8002b241 - DVI has no audio
8002F994 - To many people downloading the update just sit back until the morning around 5am - 11am and you should be able to get it.
8002F997 - Trying to Update the Firmware, copying to a file and installing from a USB drive falied".
8003051E - Game will not Save
8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only
WPA or none
8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security
8013030F - Check Router Page, SSID Broadcasting possibly off.
8013030F - Access Point not detected
80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.
807101FF - An error occurred during communication with the server. This is a DNS error This is a DNS error
8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back swtich and remove the
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond
80710D23 - Turn the PS3 off for a bit (30 minutes give or take) with the power toggle (not standby mode)
80029513 - Copyright Violation when attempting to install game
8003200D - Server side issue, much like the trophy syncing problems.
8001050F - System Clock Error.
8002A227 - You account has been banned, either temporary or permanently, (Check here for reason why you may have been banned).
80029780 - Unable To Activate System - You have reached the maximum downloads for an unactivated system. This will not affect systems that are already activated on your PSN account.
80010002 Invalid argument.
80010003 Invalid syscall number. A lot of the addresses in the syscall table at 0x2EB128 point to a function that only returns this value.
80010009 Operation not permitted.
8001002B Filesystem mounting failed.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
Error code says Playstation network has timed out when I try to connect to internet
This is the error message you get when you do not have a very active connection. It can also occur when you are trying to sign into the playstation network and it is taking a longer time than the stipulated amount of time.
The best advice i can give to you is to tell you this.
1. Make sure your internet connection is functioning properly and is running at a considerable speed.
2. If the above is carried out successfully, you can proceed on to delete your former connection and re-scan or save the access point afresh and give it time to test after the major set-up has been done.
3. After the testing, a screen would come up that says a lot of information about the access point you just saved, there is a line that reads "PLAYSTATION NETWORK READY" ensure that this line is active and if it does the same thing, you have to wait for some time as Sony could be updating the playstation network.
Hope this solution was of use to you? Please comment for more information and thank you for using fixya
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
I have a Dell Inspiron 1521 and the wireless card is supposedly functionly properly (device manager) and I am connected to the internet connection but browser will not load up and error comes up that the...
Try another access point from a neighbor or a friend who has a wireless network and log in with there permission (you'll need their network number) - the problem might be your home network modem. Sometimes the bar are miss leading and not necessarily accurate.
Dec 06, 2010 | Dell Inspiron 1521 Notebook
Signed out of playstation network
This is a known issue with the PSN Network today and is being caused by a bug in the clock functionality incorporated in the system. Users all over the world are affected by this and are facing similar issues.
Sony is working on the problem and the problem will be rectified soon. Kindly wait for further announcements from Sony
Please be assured that the problem is not with your unit and your system should work normally when the issue gets fixed
For additional details and status updates, click here
Thanks for using FixYa
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
An error has occurred. You have been signed out of
There is a fairly major issue occuring right across the board at this very moment with the PSN Network. Some consoles are not synching properly and causing problems like you describe.
For a full breakdown please see this FixYa Tip.
If the solution helps, please leave a vote for it. Many thanks.
Sep 11, 2009 | Brother MFC 490cw Color Inkjet...
Dreamweaver FTP Error
i would suggest that your server ip address has possibly changed. I would contact the people who support your server and ask them if anything has changed.
the fact that your website is up and running does not mean that the FTP should work. Very often your FTP server is physically separate to your web server
please rate this answer if it has been useful
thanks
trev
Feb 16, 2009 | Macromedia Dreamweaver MX 2004
Trying to connect psp to wireless network
probably because the router/access point wasn't configured properly
Jun 26, 2008 | Sony PlayStation Portable (PSP) Console
Ekse
Marvin
Marvin
