Hplc4276n lcd hdtv my unit comes on perfectly, but then fades to white screen after a few seconds. the audio is great. . no more than a minute or two at longest then fades back to all white.
Posted by tim temelcoff on
3 Related Answers
Anonymous
  • 3 Answers
SOURCE: LVM-37w1 37inch LCD HDTV
It is worth fixing but you have to replace the power supply. It is a fairly common problem with the Westinghouse units.
Posted on Oct 24, 2007
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: turn set on picture for a few seconds then it
Check to see if you are getting 12vdc feeding the T-CON board. the gray glowing means the backlight is working.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 04, 2010
Testimonial: "Thanks very helpful info and links"
SOURCE: vizio lcd sreen fading out.
This same thing just happened to me, don't mean to awaken a dead thread, but apparently VIZIO still hasn't fixed it. I found that the solution is to restart your computer or whatever device you're connecting via HDMI, unplug the HDMI component from the television and the device, wait for it to come back on, and then plug everything back in. Rinse and repeat if it doesn't work. Took me two tries to get it to work.
Posted on Mar 03, 2013
How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck.
Serge.
Oct 01, 2015 | Samsung LNT3242H Television
I have an lg 52LG70, 3 years old. recently, after i hit the on button, the tv will come on, but within seconds, fades to black, starting at the corners, moving to the middle. still have audio. a few...
Tv have 2 long LCD inverter boards it probally require replacing.These 2 long LCD inverter boards job are to provided the tv LCD screen panel to have a backlight to the tv LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Mar 22, 2011 | LG 52LD550 52Inch 1080p 120Hz LCD HDTV...
I've had a rca model l32hd31yx12 and recently began to get white vertical lines after a minute they fade but certain screen changes like volume adjustments and the lines come back and fade again same thing...
Sounds like the power supply has filtering issues, in other words bad capacitors. its best to have a tv shop take a look at it. they shouldn't charge you. good luck
Nov 06, 2010 | RCA L32HD31 32 in. LCD HDTV
Turn set on picture for a few seconds then it
Jul 03, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
Insignia? 37 720p Flat Panel LCD HDTV will not
Power-cycle the unit (turn it off and unplug for several minutes). If you're unable to power the unit on successfully, the TV probably requires repairs. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Jan 03, 2010 | Insignia 37" LCD Flat-Panel HDTV
Vizio lcd sreen fading out.
Well time will tell if this is a true solution but I experienced the same issue. Originally I was able to get the TV to work by turning it off and back on.
After some research I notice the the Vizio FAQ mentions a similar issue for which the solution is to unplug the unit for 3min.
After calling Vizio, they suggested that under the menu option Setup, Picture, Advanced Video Features, I should try turning off Advanced Adaptive Luma and Backlight Control.
Aug 14, 2009 | Vizio VOJ370F 37 in. LCD TV
White lines and fade desktop icons on screen
The LCD screen is at fault. If your lappy is in warranty try replacing it. It would cost araound $50-$80
Thank you!
Sabharish
Jun 01, 2009 | Toshiba Satellite M30X-S181ST Laptop
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
