SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
SOURCE: HOW TO PUT BACK BLADES ON WAHL FLAIR 8745 MODEL
you should place the moving blade first on the stable blade,then screw the 2 blades to the clipper
SOURCE: need wahl stable pro parts
Wahl Clipper Corp
2900 N. Locust St.
Sterling, IL 61081
815-625-6525
SOURCE: does the Wahl Model AC Trimmer have an adjustment
Wahl has two type of blades for this AC trimmer, some come with a fix blade no adjustment,the other type of blade has adjustable blade. Wahl dose market the blade as adjustable or non adjustable. But mannyssharpening.com has the adjustable blade type were they can adjust the blade for a close cut.
