Make sure that your router is connected to the internet. Just because devices are connected to the network it doesn't mean that they will have internet access.
Have you tried to 'forget' the Wifi network and reconnect?
https://www.wikihow.com/Forget-a-Network-on-Android
Or you could try to reset network settings:
https://www.wikihow.com/Reset-Network-Settings-on-Android
Be aware that may erase some configuration files.
SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
SOURCE: Connection to wifi internet
Try a new partnership with your pc and and use active syn to update your phone.
Under connections you'll find wi-fi in theresomewhere and choose it as default connection and you should be good to go.
Hope this els,
Steven John
SOURCE: I cant get internet on my itouch although im connected to a wi-fi
My mp4 turns on and the screen turns blue and then it says loading.I cant get it to do anthing past now loading.How can i fix this,?i have tried everything.
SOURCE: wi-fi connection
1. First, you have to make sure that the Wi-Fi of your laptop is turned on.
2. Make sure that there's an available wireless network in your area so that you can test if the computer can detect any available network.
3. If you're running Win XP, right-click the wireless icon on your system tray and select "View available wireless networks"
4. If you can't detect any wireless network, right-click the wireless icon on your system tray and select Open Network Connections.
5. Right-click the Wireless Network Connection icon and make sure to enable it.
6. If it's already enabled, try to disable it and then re-enable it.
7. If you can't still detect any wireless network, try this:
- Click the Start > Run > type msconfig > hit Enter
8. Locate the Wireless Zero Configuration and click on it once.
9. Once it's highlighted, locate the Start button on the upper left hand corner of that screen.
10. After starting the Wireless Zero Configuration (WZC), try to detect the wireless network again.
