Question about Radio Communications
Looking for a schematic diagram for a Victrola radio model VTA 750
Posted by Tony Visneskie on
David Tickner
    Sergeant:
  • 159 Answers
You might be lucky but I would doubt it, to me its another Chinese funny, things made for certain companies or supplied to companies who are the sole or limited suppliers.
I noticed on the rear of the instruction manual it only gave a short labour warranty and had its company location, most of these type purchases require return to the place that sold it or they will give a service agent to send it to.
I have found that with these items parts and manuals are not around so if you are going to fix it yourself you would have to wing it, as they can be made with a variety of parts not the same set as time passes.
Hope this helps in some way.........
Posted on Feb 04, 2020
5 Related Answers
voodoomox
marlon john madrid
  • 1689 Answers
SOURCE: wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
Posted on Jul 24, 2008
Anonymous
  • 93 Answers
SOURCE: Schematic / wireing diagram
Easiest thing to do would be to meter out your power connectors, and locate the various voltages that way. Use a multimeter that can read up to 20v DC, and go round the connectors. On most PSU's the black is negative, and the various colours represent the other voltages.
Posted on Mar 05, 2009
tim winter
  • 200 Answers
SOURCE: schematic diagram of a 1981 yamaha 750 virago carburetor
Should get a good view of it by downloding free manual at
carlsalter.com...good Luck to you friend...Tim
Posted on May 13, 2009
Azrael SRL
  • 11800 Answers
SOURCE: rca victor victrola model 77u serial#b017278 what
Circa 1950, mass produced item. In perfect condition - with a working turntable, needle included - around $80.
Posted on Jun 11, 2010
Grubhead
Grubhead
  • 5700 Answers
SOURCE: i have recently acquired an old rca victor
I don't know the model in question, but all you need to know is what type of cartridge can be used with the amp. Ceramic or Magnetic? Once you know that you can fit any that will phyiscally fit in the headshell of the deck of the type that can be used with the amp.
Posted on Sep 02, 2010
Testimonial: "thanx good job "
Looking for a schematic or circuit diagram for a Cobra CB radio from 1999 model 25 NW LTD. I can find NW or LTD but not both. Thank you.
The Cobra radio's are pretty much the same for each type. A schematic for the 25 series, 29 series, and others are very similar. The PCB's are generally the same. The only differences are usually the additional features, maybe an extra button or control, etc. The schematics for the most part are the same with the various features added.
The only way that I know this is I have repaired many of the Cobra 29 series, and a few of the 25's and noted the similarities. Many of the boards were manufactured by Uniden and others. There is about a 10 digit part number on the circuit board that you can google. You can usually find the schematic from that alone.
Jan 19, 2018 | Cobra Radio Communications
PERMANENTLY DISABLING ANTI THEFT ON 1995 JEEP CHEROKEE
see this link
what makes you think its (anti theft)??
all jeeps made with Immobilizer, (VTSS/VTA its called then)
the cluster has lamp that tells you VTSS has imobilized the engine (cuts fuel)
if the immo lamp is on, then see below.
93 was first year, click hack 93-98
http://jeepdied.com/
if not glowing that immo lamp
that means its just a no start.
cranks but will not start has over 50 causes.
covered on same page but is called no start.
ZJ 1995
this is the VTA page 8q in the fsm
The Vehicle Theft Alarm (VTA) system is an available
option on Grand Cherokee models. This system
is designed to protect against vehicle theft by monitoring
vehicle doors, hood, liftgate and ignition action
for unauthorized operation. When unauthorized operation
is detected, the VTA system responds by sounding
the horn, flashing the headlamps, park and tail
lamps and providing an engine no-run feature. Following
are general descriptions of the features of the
VTA system. Refer to Group 8W - Wiring Diagrams
for complete circuit descriptions and diagrams
see that lamp below, this tells you what's up.
26166726-iznfychya1k5sjkhauts20c0-4-0.jpg the lamp glows key on to tell you Im alive and that im ok booting up. but then goes out to start car.
does it?
Apr 17, 2016 | 1995 Jeep Grand Cherokee
HOW DO I PERMANENTLY DISABLE ANTI THEFT SYSTEM ON MY 1995 JEEP CHEROKEE
see this link
ZJ 1995
does it?
2008 Chevy Impala radio wire digram
you are going to have make and model ## of the car stereo, if GM
still go to have model ## off the back of stereo and what would be better is a part number would be very good.
www.freeproductmanual.com
www.infolink.com
www.wikipedia.org
schematics
www.eserviceinfo.com/equipment_type/schematics
www.free-schematic.blog.spot.com/
www.electronicshelponline.com/radio_wire_diagrams
other sites for help
www.manualsonline.com/radio_wiring_diagram
www.wikipedia.org/wiring diagram radio
www.alltheinternet.com/radio_wiring_diagrams
Feb 25, 2015 | 2008 Chevrolet Impala
Old radio schematics
Here is the link to a radio museum where you can find the schematics of your radio. There is a catch. To access full-size diagrams you must register as a member. Your model is on the list.
USA Radio Catalog for the radio manufacturer Western Auto Supply Co...
Feb 11, 2014 | Audio Players & Recorders
I looking for sxematic diagram uniden pro 510xl
I hope you find the schematic diagram for your radio......
Aug 25, 2011 | Uniden PRO510XL 40-Channels Base CB Radio
Rca victor victrola model 77u serial#b017278 what year was this manufactured?what is its monetary value?
Jun 11, 2010 | Audio Players & Recorders
Schematic diagram of a 1981 yamaha 750 virago carburetor
Mar 02, 2009 | 1981 Suzuki GS 750 L
Radio Communications Logo
166 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
