Question about Sunbeam Heating & Cooling
My sunbeam warming blanket control wont stop blinking
Posted by Nikki Treadway on
5 Related Answers
Anonymous
SOURCE: My Sunbeam electric blanket controls
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Posted on Dec 22, 2008
Anonymous
SOURCE: electric blanket does not warm
Call the manufacturer. They will often do repair for free.
Posted on Dec 31, 2008
Anonymous
SOURCE: Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Posted on Feb 22, 2009
Joe Hogan
  • 10865 Answers
SOURCE: my dual control sunbeam electric blanket flashes
Return this product as it is a fire hazard.
please mark this as a fixya! thanks
Posted on Mar 17, 2009
woodzowl307
  • 667 Answers
SOURCE: my sunbeam electric blanket - the heat controller ...
do away with the blanket, as it is an electrical issue, hazard!
Posted on May 22, 2010
E on controlls
If you have a digital control, it is designed to flash "E" on the display to notify you that a problem may have been discovered. Gradient controls and warming throw controls use a blinking indicator light for this purpose.
Follow the instructions on the flag tag to reset the control or follow the steps below.
  • Unplug the system from wall outlet.
  • Check that the control is well connected to the module.
  • Plug the power cord into the wall outlet.
  • Set the control to "on".
If the system still does not operate, disconnect the power cord and contact sunbeam
Sites sunbeam Site
Jan 11, 2015 | Sunbeam Twin Heated Blanket Navy Blue...
Se My blanket is blinking F2 and I can't set the controls
To reset the control:
1) Unplug the blanket from the wall outlet.
2) Check that the control is well connected to the module. (Disconnect and re-connect it).
3) Plug the power cord into the wall outlet.
4) Set the control to "on".
Try 1-4 three times. If the blanket still does not operate, disconnect the power cord and contact Sunbeam Customer Care at 1-(800) 892-7684.
Oct 07, 2014 | Sunbeam Electric Blanket - queen
One control works and not the other control
I have a Sunbeam electric blanket. One control is blinking F2. How do turn that off?
Mar 05, 2014 | Sunbeam California King Arlington Heated...
One of the controls will not turn on. The cord is
Try swapping the controls and see if the problem stays with the control or the blanket side. In any case I would go on line and contact Sunbeam, they are a very reputable manufacturer and I would be surprised if they do not stand behind the product. You will be able to tell them if it is the control or blanket. If the other side of the blanket gets warm when you switch the controls it is the control if the same side gets warm it is the blanket. If neither side gets warm is is the blanket and control.
Good Luck,
Gilshultz
Dec 03, 2009 | Sunbeam SG7621SP Grill
Sunbeam Electric Blanket Model 972 A5 Type 692 (or 592) with temperature control 1 to 9 with 75 mins and 12 hrs and off control positions. The light blinks red and the blanket won't heat up. Please...
Did you get helped last year? If so please ignore. Otherwise....
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $69,95 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
Apr 08, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
My Sunbeam electric blanket controls blink when I plug the control cable into the blanket. I cannot turn the controls on or off.
Jul 21, 2008 | Heating & Cooling
Heating & Cooling Logo
126 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
