Precision m90 LAPTOP PC. 14 years old came with XP.
the screen is dead , does the monitor work on other PC?
fans in PC spin , heard or seen.?
step on ALL LAPTOPS remove the now very very old big battery now and test the LAPTOP with only the AC power pack as power.
work now/ ? yes, then buy a new battery.
next is the RTC coin cell ,none last 14 years either .
SOURCE: Dell Precision M90
Try installing other anti-virus like NOD32 or karspersky. You can also try to do a system restore, this may or may not solve the problem though,also using the system restore may get rid of some application you have install prior to the date you will revert it to.
Or you can try this online virus scan
http://housecall.trendmicro.com/
http://www.bitdefender.com/scan8/ie.html
http://www.kaspersky.com/virusscanner
have them scan your system (its free),that way you'll know if your computer really has a virus or not.
SOURCE: Connecting Dell Precision Laptop to Samsung 29 inch Easy View (CRT) T.V
dear sir.
here u have to chek cable yr laptop is not support with a same s-cable u need to connecter for s-vadio to audio vedio connector and it's convort yr s-cable to comosite cable afer that it's automaticly dosply thru composet.... yeah one thing have to chek with different cable then selacet display propatise to set output setting is set in to s-video.. it's help u...:)
Thanks
please vote
jo_chinmay
SOURCE: hi my dell precision m90 has problem. While I'm
The M90 has 2 fans (1 processor and 1 video card) http://support.dell.com/support/edocs/systems/wsM90/en/sm/fans.htm#wp1000550
while the fans can be passing diags, the system could still be having a cooling issue. Some things you can do are:
If issue still occurs after all of the above, then replacement of the video card may be required
SOURCE: Dell precision m90 overheats randomly
Either your motherboard has gone bad, or you fan AND cooling grid needs replacement. The grid is simply a series of metal bars, so to speak, which absorb heat to be passed out of your system with the cooling fan. The cooling fan has 2 speeds. If the system is not kicking in the higher speed on the fan, it's more than likely a bad motherboard. Also, make sure you keep your laptop plugged into the wall as much as possible. Going on battery alone does slow down the processor considerably to conserve the battery.
Best wishes.
SOURCE: how to clean out dell
http://www.youtube.com/watch?v=0yyEVSkz_0M - similar laptop
http://www.youtube.com/watch?v=4ODaKRx7WPw - the lazy way!
