Check the equilibrium of speaker
Check the equilibrium of speakers
Check the equilibrium of speakers balancess
SOURCE: Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
SOURCE: Volume on my Onkyo Receiver
Yes it is. I have the 705. My room mate has the 605. Both AVR's will not have appreciable volume until 50 on the dial.
The dial in not linear. I don't know of anyone who has plotted the scaling of the volume control yet.
I have found much useful user info on avsforum.com. Owners post Q&A based on experiences.
Search the forum for "official onkyo TX-SR605" thread.
Some comparable info may also be found under the "official onkyo TX-SR705".
SOURCE: is the onkyo mic optimizer compatible with yaama receiver
No, they are brand and model specific. If you visit a local retailer that sells Yamaha, tell them your model # and they may even have a mic you can use. If not, let me know, I'm a Yamaha dealer and can get it for you or point you in the right direction to get it. Hope this helps
SOURCE: Speaker Detect error Left Rear
Hey there.
I had the same problem until i figured out that if u dont have surround speakers connected it will be a error when trying to configure the rear surround speakers.
So if u are running a 5.1 system and have hooked up ur surround speakers to the back surround speaker port u have to change them to the surround speaker port.
Hope this work for u
SOURCE: Onkyo 501 Onkyo Receiver no sound out of right
if you are good at tinkering then you can pulol the top of the receiver and check the fuses on the board to make sure that they did not blow if not then it would be wise to take it to a repair shop to have your receiver checked out and serviced
