Question about Kenwood Computers & Internet
Conecte un estereo kenwood DNX6140 a mi tahoe 2002 pero la funci?n del subwoofer no funciona que puedo hacer
Posted by Nelson Diaz on
Marvin
    Top Expert:
  • Kenwood Master
  • 85,239 Answers
English
Posted on Jan 04, 2020
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: mp3 no lo lee mi compu
Firmware upgrade needed - RCA website - select "Spanish" for language
Posted on May 24, 2008
Anonymous
  • 8637 Answers
SOURCE: NO PUEDO HACER QUE FUNCIONES IR-323O
Double click on the site for I-rocks Camera driver, go down to Multimedia and download the driver. http://www.i-rocks.com/Download.aspx
After you download the driver, then do this:
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Posted on Apr 03, 2009
Anonymous
  • 655 Answers
SOURCE: necesito el code,pero no tengo control remoto.
Hola zubiate712,
Usted puede comprar el teledirigido en línea del almacén accesorio de Kenwood.
El número de modelo para su KDC-MP235 es RC-557 y el coste es el envío más $9.75.
Espere que esto ayude.
Posted on May 27, 2009
Anonymous
SOURCE: no puedo usar mi camara para chatear
no se como usar la camara de mi laptop ayudenme
Posted on Dec 23, 2009
elliljoker92
Edward Talavera
  • 140 Answers
SOURCE: mi psp funciona bien;pero cuando conecto la psp
te vas alas opciones i hay un lugar donde dise algo de usb conecion conectas tu psp ala computadora y luego le apachuras donde dise usb coneccion i en la computadora va a salir un folder y aista
Posted on Apr 27, 2010
119helpful
3answers
COMO DESBLOQUEAR LA CASETERA DEL DVD SONY DVP-SR320
prendo el dvd y cuando quiero sacar la bandeja me sale bloqueado que puedo hacer grasias
1helpful
6answers
Nesesito saber el codigo para un tv mitsui
Mitsui 0067 0586 0517 0039 0265 0041 0385 0102 0066 0247 0324 0401 0463 0473
0393 0609 0485 0193 0379 0546 0065 0238 0075 0225 0221 0365 0574 0744
1067.
12helpful
9answers
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Recientemente conecte la Pc a internet y al realizar las actualizaciones, en el reinicio en el momento de configurar las este win no arranca se apaga y prende en un ciclo que no acaba. no dispongo de disco...
Usted puede tratar de arrancar en modo seguro pulsando F8 durante el boods m?quina. Una vez en modo seguro se puede tratar de hacer una restauraci?n del sistema de la, en Inicio, Todos los programas, accessores Herramientas del sistema • Restaurar sistema. Si esto no funciona, entonces usted tiene que hacer una restauraci?n completa del sistema o la recuperaci?n del sistema en funci?n de su computadora. La mayor?a de los nuevos equipos le permitir? hacer una recuperaci?n del sistema pulsando una de las claves durante el arranque. Usted va a perder todos los programas y todo lo que est? en el equipo. Usted puede ser capaz de hacer esto sin tener que formatear el disco duro.
I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
3helpful
2answers
No enciende las vocinas para mi computadora son logitech x-530 quiero verificar como puedo cambiar los fusibles o verificar cualquier cosa que sea para cambiar pero como destapo los subwoofer para...
Primero trata con otra fuente de energia electrica otro tomacorriente u otro sitio a ver si no es el sistema de cornetas, para abrir el sub buffer solo encesitas destornilladores y verificar dentro el estaod de los componentes si tienes voltimetro mejor, cuidado con hacer cortos. pero no hay uan guia basica para eso, solo saber lo que haces.
2answers
Mi monitor parpadea y no arranca ? que debo hacer tengo conocimientos de electronica pero no se que hacer
Primero verifica la luz frente a tu monitor si la misma esta parpadeando o de color anaranjada hay un problema con la tarjeta de video de tu computadora. Si esta verde esta recibiendo señal de tu tarjeta de video. La mejor forma de saber si tu tarjeta de video esta funcionando correctamente es utilizar otro monitor que sepas que esta funcionando correctamente y conectarlo a la computadora. Si funciona bien, tu monitor esta dañado. Mi recomendación es compra uno nuevo por que es mas economico que repararlo.
Hola espero puedan ayudarme... mi telefono no le funciona la pantalla tactil y se me kedo blokeado asi ke le di un hard reset y todo bien pero el problema no termino porque ahora para iniciar el telefono...
hay muchos htc g1 que tienen el mismo problema parese que nadie pouede darle solucion.... yo tambien tengo un g1 pero no se que puede pasar.... ando en tar de solucionar el problema... que sera...
Sep 18, 2010 • HTC G1
Necesito el code,pero no tengo control remoto.
Hola zubiate712,
1helpful
3answers
Palanca de cambio de velocidades no funciona
posiblemente la barra que conecta la palanca de cambios se solto de alguna manera. Con el motor apagado, mientras se mueve suavemente la palanca de arriba a abajo, revise debajo del tablero empezando en la columna de direccion. Una vez que la barra haya sido localizada, sigala can la mano hasta encontrar donde esta desconectada o suelta. Yo tuve el mismo problema en mi camioneta ford hace un par de anos, encontre que la palanca se habia soltado de la barra, todo lo que tuve que hacer fue apretar un tornillo que estaba suelto.  Posiblemente despues de un tiempo vuelva a ocuriir el problema si no se asegura de que el tornillo este bien apretado o de que la palanca de cambios no este totalment hacia arriba en Park. Buena suerte desde Houston, Texas.
Computers & Internet Logo
Top Kenwood Computers & Internet Experts
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Kenwood Computer and Internet Expert? Answer questions, earn points and help others
