Question about Canon Video Cameras
The cassette loading motor or the capstan motor and its shaft or head drive motor may be struck loosen with contact cleaner and give a little shake.
Posted on Feb 29, 2020
SOURCE: Lasko 5610 red caution light, no power
In the bottom of th e 5610 there are 2 automatic reset breakers. In betwene the two there is wire connecting them together. In the middle of this wire is a thermal resister and thats what repaired mine. Replace it and your heater will heat again.
Posted on Mar 06, 2008
SOURCE: no image on viewfinder
There is a short in the wiring were the hinge is at. You can take into a camera store or Best Buy and see what it would cost to replace the wiring in there.
Posted on Nov 19, 2008
SOURCE: Charging lights turn red and green...But camcorder will not power on
All right if you have the same problem that i had what you need to do is take the battery out the take the memory card out the put the battery back in then try and turn it on if it works then put the memory card back in and it should be fixed
Posted on Jul 08, 2009
SOURCE: Canon XL1. Unable to playback tape in camcorder
I have the solution that the canon expert forgot to mention. And this solved my exact problem too. I put in the tape and then shut the white door over top. This doesn't engage the tape. Problem solved. Human error, The fix cost nothing.
Posted on Dec 21, 2009
SOURCE: Canon ZR90 Mini DV Digital Camcorder no power even
Batteries may need to be recharged or replaced if the error persists after battery recharge or replacement the unit may require a service evaluation. If the batteries currently in the device and it is not working properly, remove the batteries and wait for 30 seconds and re-insert the batteries. In doing so if your camera has a back-up or date and time battery, remove this battery as well. Removal of the back-up battery will cause a full reset of the camera and will clear any settings, including date and time.
Posted on Mar 13, 2011
Oct 25, 2009 | Canon XL1S Mini DV Digital Camcorder
Feb 28, 2009 | Canon XL1E Mini DV Digital Camcorder
Jan 27, 2009 | Canon XL1S Mini DV Digital Camcorder
Dec 25, 2008 | Canon ZR85 Mini DV Digital Camcorder
Dec 19, 2008 | Canon Video Cameras
Dec 12, 2008 | Canon ZR60 Mini DV Digital Camcorder
Nov 19, 2008 | Canon DV-MV830i Mini DV Digital Camcorder
Aug 20, 2017 | Canon Optura 300 Mini DV Digital Camcorder
Jun 15, 2008 | Canon MV630i Mini DV Digital Camcorder
Jun 16, 2006 | Canon MV600 Mini DV Digital Camcorder
112 people viewed this question
