Question about Cuisinart Food Processors
Cuisinart PowerBlend Duet BFP-10 Series lights ON but function buttons don't work
4 Suggested Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
Posted on Mar 17, 2009
msbigdog7
Mabron Stevenson
  • 332 Answers
SOURCE: I can't find replacement jar for Cuisinart Smart
You will have to call the company directly to special order it
Posted on Sep 05, 2009
jbanks2
Joe Banks
SOURCE: My cuisinart smartpower duet BFP
Mine did the same thing... Had to replace the drive clutch.
Cuisinart SPB7 Clutch
Posted on Aug 14, 2012
greasedsilve
Merle Evans
  • 266 Answers
SOURCE: My Cuisinart SmartPower Duet Chrome Blender/Food Processor Model BFP-703CHTX5 Buttons light up red when pressed, but nothing spins. Blade assembly feels very tight. Spindle does not spin as well.
Sounds like you've lost a motor. Same thing happened with my Kitchen Aid. Toasted motor.
Posted on Dec 23, 2016
Lights come on, motor turns briefly, then stops
Check that blade can turn easily with unit unplugged. Fix that first then replace the fuse.
Dec 15, 2012 | Cuisinart BFP-703 SmartPower Duet Food...
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
-Tha Mp3 Doctor
Feb 01, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Lights all Come on, Then spins up a few seconds then dies
Remove work bowl completely - then try the various buttons. If no spinning occurs with work bowl removed, the motor is dead. Find out from Cuisinart if you are still under warranty, and send in for repair.
Jun 08, 2008 | Cuisinart BFP-703 SmartPower Duet Food...
Drive gear link on top of Cuisinart motor broken
I bought two for $10 plus shipping from buyitnowstore.com. The remaining metal piece from the plastic "clutch" is hard to remove and I have not figured that out yet.
Jan 11, 2008 | Cuisinart BFP-703 SmartPower Duet Food...
Food processor
If the blade is actually fused, I would seek professional help to avoid slicing your fingers off. You can test to see if it is fused by removing the lid of work bowl, twisitng work bowl to the left, and removing the work bowl - if work bowl will not come off (difficult even under normal circumstances), then find out from Cuisinart if you are still under warranty.
Jul 14, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Food Processors Logo
37 people viewed this question
Top Cuisinart Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Colin Stickland
Colin Stickland
Bruce Showalter
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
