SOURCE: the wire diagram on my
This unit is was sold by Graingers. You will need to call them to see if they can get you any literature for your unit. Check the link below.
Good Luck,
Jim
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=3e226&op=search&Ntt=3e226&N=0&sst=subset
SOURCE: dayton 3e226e fan runs but burner will not light
Hello, since the inducer motor is running this can be either a bad ignitor or a pressure switch problem. Jump the pressure switch to see is the furnace will run, if it does there is a problem such as clogged vnt pipe, tubing clogged from switch to inducer motor, or the switch itself is bad. If it does not run most likely a bad ignitor
