Question about Haier Refrigerators
How long before a new fridge gets cold. Haier 514l French doors
Posted by Brian Dorber on
David Spradling
    Top Expert:
  • Haier Master
  • 10,914 Answers
Should within an hour if you tipped up on side and turned on before 24 hours ruined compressor
Posted on Feb 01, 2020
5 Related Answers
Bill Dozier
  • 262 Answers
SOURCE: Maytag french door bottom freezer: Fan not working.
very easy the fan cover snaps into place and make sure you get the new motor that is metal not the plastic one they are the problem
Posted on Jan 08, 2009
Anonymous
  • 1066 Answers
SOURCE: haier fridge- freezer fine, fridge not getting
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
jeffbvegas1
Jeff Barton
  • 520 Answers
SOURCE: LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Posted on Jun 26, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: freezer working fridge not
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks!
Posted on Jul 19, 2009
Anonymous
SOURCE: Fridge will not get cold
Was your fridge transported upright at all times? There are warnings on most brands not to lay them down due to potential damage. If that was not the case, those small units are often easy to repair.
[Note to garing: The person said there was no ice anywhere but on the back. Dorm sized refridgerators are rarely frost free, so your answer was pointless.]
Posted on Aug 18, 2009
Where is the relay switch on a haier french door fridge
probably, but I don't know what exactly you are looking for and why.
Dec 06, 2016 | Haier Refrigerators
How do I get my new Samsung RF220 to be cooler in the refrigerator section? The temperature does not go below 52degrees F. It is set at the coldest setting.
Check for deformed rubber boot that runs entirely around edge of fridge door allowing cold air in fridge to leak out. 2nd possibility: Louvers in wall between freezer and fridge may be stuck in mostly closed position. Force them GENTLY to open. That will allow the cold air to pass normally from the freezer to the fridge to give you proper fridge temps. If these two easy cures don't work, here's hoping that Samsung owes you in-warranty service and parts on your "new" unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/gramps_bab85ce284d72c1d
Oct 12, 2014 | Samsung RF220NCTASR 21.6 Cu. Ft....
My fridge isnt cold freezer is our friend gave it to us she has no idea its our grage fridge fridigdare elite not brand new
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 10, 2011 | Maytag MFD2560HES Bottom Freezer French...
Fridge not cooling
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 31, 2010 | Haier Convertible Bottom Drawer French...
Our Kemore Elite French Door Fridge is not working. The Freezer is freezing but the fridge is not cooling at all.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jul 22, 2010 | Kenmore 77552 Bottom Freezer French Door...
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
New french door GE fridge that won't stay cold
If " new " is less than 1 year , you will need to call GE factory service , for a warranty repair . If any one else works on it , this will void your complete warranty , and they will charge you for a service call + parts + labor .
Nov 13, 2009 | GE Refrigerators
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Condensation on the strip between the 2 french doors
these fridge have a heater in that black flaper to prevent condensation. It is probably not working or not even plugged...do they removed the doors when they delivered your fridge??? remove the uper left cap of the hinge, the connection is there...... the tech must check that piece if it is well plugged..
Jul 03, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Dec 11, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
78 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
