Question about Sewing Machines
FO5 speed sensor stops my sewing machine and won't go off Untill I shut it off, how to fix it.?
Posted by Lenora Heidemann on
ray gallant
    Top Expert:
  • Sewing Machines Master
  • 68,551 Answers
WE HAVE NO CLUE AS TO WHAT MACHINE MAKE OR MODEL OF WHAT YOU HAVE SUGGEST YOU TRY THE MANUFACTURER'S WEBSITE
Posted on Jul 15, 2020
4 Related Answers
SOURCE: sewing machine speed it won't stay the same
if you have a speed control on the machine & you set it & the stitches are not staying constant, then the machine needs to be serviced
Posted on Mar 14, 2012
SOURCE: hi i have a brother innovis 700eM11 and fo5 speed sensor keeps coming up on thescreen i have to shut it down and start the pattern again,have you any idea as it doesnt mention this in the manual than
the sensor may be going out,, the speed control could be going out,when was the last time the machine was serviced?
Posted on Apr 13, 2012
SOURCE: kenmore 385 was sewing then motor shut down no power, wheel turns fine just machine won't come on
it's very possible that the motor went out & would have to be replaced
Posted on Apr 22, 2012
SOURCE: .turn mach. on, it starts running and won't stop until you shut it off
sounds like their is a short some where in the machine and it needs
to be checked.
Posted on Apr 03, 2013
My brother sewing machine LB 6800 is showing FO5 speed sensor error what can I do to fix it
You may need to get the sewing machine serviced; the repair must be handled as if you are fixing a computer. The F05/F5 error indicates a problem with the timing shutter, the PCB board or the wiring between them.
If you are going to try this, first unplug the machine and check the wiring. Next clean the timing shutter if the wiring is undamaged. Replace the timing shutter if the error recurs. If the machine still gives the F05 error, the PCB board has to be replaced.
Some of the parts for the Brother LB6800 are here: https://www.sewingpartsonline.com/brother-lb6800-sewing-machine-parts.aspx?sort.ss_cat_sort=desc&index=157.
I hope this helps.
Sep 29, 2018 | Brother Sewing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
My Janome memory craft model 9000 sewing machine is now sewing at one slow speed. The quality of the stitch is good but too slow what should I look for?
Your speed slide sensor is bad. Your local repair shop can fix it. There is a chance it's the foot pedal. If it's still slow when you sew without your pedal, then it's the sensor.
Feb 25, 2015 | Janome Sewing Machines
F05 speed sensor
Make & Model ??
Feb 28, 2014 | Sewing Machines
to be checked.
Apr 03, 2013 | Husqvarna Viking 1
Singer stylist 534 sometimes when you stop won't start without turning balance wheel
Yes this is normal especialy with heavier fabrics. It allows more control so you build up speed gently. It is also related the limited power of the motor.
Mar 01, 2013 | Sewing Machines
Brother pe-770 f05 speed sensor error - How to fix?
F05 error, speed sensor. I fixed successfully 2 of those. Speed sensor is located on a small board, under a protective plastic, located over the main front board. Remove front panel and bobin winder assembly. Remove the 2 screws of the small board. Remve CAREFULLY the small bord. Under, on the main shaft, are located the needle positionning sensors and the wheel of the speed sensor (left wheel on the shaft). The speed sensor is located on the board itself, it's very small. Clean carefully both the wheel and the sensor with Q-Tips and alchool, reassemble the whole thing and it should restart.
While U are there, take a thin nozzle oiler and lubrificate all the suppots of upper and lower shaft, all the needle bar mechanism and rotary hook central shaft and gears WITH VERY THICK oil. Needle bas assembly is the most critical point. I have 14 of those machines, almost all of those seized there before I learn how to lubrificate it. Also seized on the bottom shaft and on rotary hook pin
Jun 26, 2012 | Brother PE770 Computerized Sewing Machine
Sewing machine speed it won't stay the same
Mar 13, 2012 | Kenmore 19365 Computerized Sewing Machine
Sewing Machines Logo
96 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
