Question about Hardware & Accessories
Our utilitech pro model 6290 standing light will not light up. see below
The light would only work if the light arms where in a specific position, and as soon as you would move it the light would go off. Is there anyway to "troubleshoot" this without buying a whole new light?
Posted by carly dorval on
gbob59
  • 3,063 Answers
Owner's manual troubleshooting? Otherwise my wild guess: Change the arms without power, tighten and retry plugin.
Posted on Jun 29, 2020
4 Related Answers
gypsycat00
Joseph Weisenberger
  • 224 Answers
SOURCE: The arm of my belt tensioner seems to be missing a part.
Is the belt loose? It sounds like you're missing the pulley. Pulleys are usually available from Autozone or Napa (usually one bolt through the center to secure it to the arm).
Posted on Jul 01, 2009
Molson02536
Harvey N Tawatao
  • 3854 Answers
SOURCE: Where is the cam shaft position sensor located?
It's not that hard to replaced, and can be done with common tools.  3.4 camshaft sensor removal:
Remove the serpentine belt, Disconnect the sensor wire harness, Remove the power steering pump (just remove it from the mount and out of the way), Remove the attachment bolt to the sensor, Remove the sensor, (note spray around the sensor with brake parts cleaner before removal to keep dirt from entering the engine)
To install: Lubricate the new O ring with engine oil before installing the new camshaft sensor, Tighten the retaining bolt to 8 ft.lbs.  connect the sensor's electrical wire, reinstall the power steering pump, reinstall the serpentine belt.
Start the car and go out for the night with the money you just saved, You can pick up the camshaft sensor at Auto Zone and they can also give you the step by step instructions to getting the job done. Good luck and hope this helps. Take's just under 1 1/2 hour to do. You can do it in under 1 hour though if your good with tools.
joejaydee
SOURCE: I bought a 2004 Lancer
i bought a used 2004 mitsubishi lancer ls sportback with the same problem. a google search told me this was a known defect and was covered under a dealer recall--no cost to me. my local dealer did the job. it took at least a half day--the entire dash, they said, had to be removed. the fix isn't perfect, but it is light years above and beyond what it was b4. the new knobs aren't silky smooth, but the old ones needed tools to turn!
Posted on Feb 06, 2011
Okeoma Emmanuel
  • 1156 Answers
SOURCE: I have a UMC TV
Hi, you can use the link below to buy stands for TV's.
http://www.amazon.com/Cheetah-Mounts-ALAMLB-Bracket-Articulating/dp/B001GTT0VO/ref=pd_rhf_shvl_2
http://www.amazon.com/Cheetah-Mounts-APTMM2B-Bracket-Universal/dp/B0012S4APK/ref=pd_rhf_shvl_2
Hope it helped..
Posted on Jun 21, 2011
My floodlights Utilitech 6211W-PIR23A come ok but will not turn off at night, on test they work ok.
light sensor failed or covered in dirt. or you have set it on double switch that means the stay on. to turn off permanent light flick the power on to the lights on off on. should go back to timer that has been set. 3 5 10 min.
Apr 19, 2018 | Utilitech Pro 180-Degree 2-Head LED...
Utilitech Pro, model 0595683. Can I use a dimmer with this LED fixture?
It appears, no you can't use a dimmer on these lights. You can try a CFL / LED rated dimmer, but it still may not work
Jan 06, 2016 | Electrical Supplies
I HAVE A UTILITECH PRO 180 #0205881 AND IT BLINKS WHEN ITS ON
Usually when a motion sensor light blinks LED or otherwise it means that the motion sensor is shot. The light itself is most likely good and for whatever reason you got a bad sensor upon purchase.
Feb 21, 2014 | Utilitech Pro 180-Degree 2-Head LED...
Utilitech pro submersible pump has good electrical connection but pump won't start
There is a starting capacitor on the motor pump, check this out if faulty then replace it.
Dec 28, 2013 | Utilitech Plumbing
My Utilitech Pro will come on, after a few seconds it will blink twice and then will not come on again for several days.
Sounds like the sensor has failed. The controls are supposed to be on the underside, and kept dry.
Nov 24, 2013 | Utilitech Pro 180-Degree 2-Head LED...
I lost my instructions for my Utilitech #0357930 timer. I cannot get it to work; I can set it to start but not stop. Just need some directions. Buttons on it are On, Off, Day, Hour, Min, Enter, Pro
The AutoChron 81000 Programmable Wall Light Switch Timer is identical to the Utilitec #0357930 (AmerTac) TMDW50L. Here are links to manuals for models prior to and as of 2012.
Before 2012
As of 2012
Nov 28, 2012 | Hardware & Accessories
Derbi senda fuel gauge not working
Hi, Anonymous you could have a faulty sending unit or gauge, there could be a problem with your wiring. On models with the fuel gauge posing as a left-hand fuel cap the gauge is a press fit do not try to unscrew it, simply ample force lift up in a rocking motion to remove gauge. Disconnect wires to the gauge and with a set of positive and negative jumpers from the battery connect the positive jumper and flash the negative, gauge should peg full, if not replace the gauge. With a test light check for power to the sending unit, then remove the sending unit and manually operate the float arm slowly with the correct wiring hooked up to the fuel gauge and sending unit and the ignition on, the gauge should respond accordingly if not replace the float arm assembly. If your fuel gauge registers the incorrect amount of fuel in the tank you can try bending the float arm the necessary amount for a more accurate reading. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day. https://scootergrisen.dk/scooterhjemmeside/download/derbi_gp1_servicemanual.pdf
https://www.oemmotorparts.com/oem2.asp?M=Derbi
http://www.derbi.com/fr/images/stories/modelos/37/manual.pdf
Derbi Senda DRD Pro 50 SM 2011
Tips Tricks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 28, 2012 | 2011 Derbi Senda DRD Pro 50 SM
Dishwasher-bottom arm not spraying
The spray arms can usually be removed by unscrewing (clockwise or counter clockwise depending on brand and model), or squeezing a retainer to release the arm. Before removing the spray arm, place the spray arms (all) in a specific position and activate the dishwasher for a few seconds with wash action. Then examine the position of the spray arms to determine if there was movement from the spray arms. If not, then the spray arm(s) are probably clogged and restricting water flow (which makes them turn). Make certain that you are positioning the plates, glasses, etc. in the dishwasher so that they have access to the water. If still no luck, contact an appliance service company.
Feb 20, 2010 | Jade RJDW2470A Free-standing Dishwasher
Hardware & Accessories Logo
145 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
