Can't find the play button on my dvd remote. - Televison & Video
Posted by Holly Francis on
gbob59
  • 3,063 Answers
Owner's manual? No manual, try: https://www.manualslib.com
Posted on Jun 29, 2020
Where on the remote is the play button for the
Play could start automatically after the DVD is loaded.
Sep 19, 2016 | Televison & Video
Tip
Matsui DVD-110 VCD Fix
Matsui DVD-110 DVD Player VCD Playback Fix
Would you like to unlock your Matsui DVD-110 DVD Player to play VCD's?
Follow these steps to unlock your Matsui DVD-110 DVD Player:
  1. Press the Open button on your remote control to open the drive tray
  2. Place an audio CD in the drive tray
  3. Press the Open button on your remote control to close the drive tray
  4. Press the Menu button on your remote control
  5. Press the 1 button on your remote control
  6. Press the Index (1-All) button on your remote control
  7. Press the Open button on your remote control
  8. Press the 1 button on your remote control
Your Matsui DVD-110 DVD Player can now play VCD's.
I hope that helps.
___________________________________________
Matsui DVD-110 Region Free Fix
on Apr 25, 2010 | Televison & Video
Tip
Matsui DVD-122 VCD Fix
Matsui DVD-122 DVD Player VCD Playback Fix
Would you like to unlock your Matsui DVD-122 DVD Player to play VCD's?
Follow these steps to unlock your Matsui DVD-122 DVD Player:
Your Matsui DVD-122 DVD Player can now play VCD's.
I hope that helps.
Matsui DVD-122 Region Free Fix
When I play my DVD I cannot scroll down to play Episode or Play All
What type of tv and, remote are you using? In most cases there is a button on your tv remote that you need to press the dvd button o the top of the remote onceyouhave stated viewing your dvd
Oct 12, 2015 | DISH Network IR Remote Control
Cant get my akai DVD player to play all my cds and dvds
Instructions
  1. Changing Region Code on Oppo and Similar DVD Players
    • 1
      Press the "On" button on the remote control to turn on the DVD player.
    • 2
      Press the "Setup" button on the remote control.
    • 3
      Press the following buttons in this precise order: 9210.
    • 4
      Highlight the text field in the window that appears. Press "0" on the remote control to change the region code from one-region specific (the country the DVD player is sold in) to all regions so that any disc can be inserted and played.
    • 5
      Press the "Setup" button. Press the "On" button on the remote control to turn off the DVD player.
    Changing Region Code on Sony and Similar DVD Players
    • 6
      Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray.
    • 7
      Press "Clear," "1," "4," "7," "0," "Clear" on the remote control. Press up on the remote control's directional pad until you see "1224" on the screen.
    • 8
      Press "2," "3" and the "Enter" button. Press up on the remote control's directional pad until you see "1401" on the screen.
    • 9
      Press "0," "0" and the "Enter" button. Press the "Return" button. Press the "Clear" button twice. The DVD player is no longer locked into the single region that it was designed for (being the country it was sold in) and is now instead open to all regions and so able to access any disc.
    • 10
      Press the "Return" button. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
    Changing Region Code on Denon and Similar DVD Players
    • 11
      Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray. Press "Clear," "1," "4," "7," "0," "Clear" on the remote control.
    • 12
    • 13
    • 14
    • 15
      Press the "Return" button. The region code of the DVD player is now changed from being only for the country it was designated for and instead for all regions. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
PROCEED ACCORDING AND FOLLOW THE STEPS. God bless you
Apr 04, 2013 | Akai Dv-px6150k - Multi Region...
Tip
Tevion DVD-200 VCD Fix
Tevion DVD-200 DVD Player VCD Playback Fix
Would you like to unlock your Tevion DVD-200 DVD Player to play VCD's?
Follow these steps to unlock your Tevion DVD-200 DVD Player:
Your Tevion DVD-200 DVD Player can now play VCD's.
I hope that helps.
Tevion DVD-200 Region Free Fix
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Mar 13, 2010 | Philips Televison & Video
Locked dvd
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Mar 02, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
