Question about Radio Communications
How to fix Bluetooth wireless earbuds paired and connected to my device but no sound
Posted by Rachel Mata on
Adam Dawson
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Make sure that the pair on your output device states paired for phone and music. It can still pair for phone and data but not pair to stream music. This is common on android devices especially. If this be the case, unpair the device and forget (delete) the earbuds on your output device. Ensure any bluetooth devices like amazon Alexa, TVs and other common things are powered down. Turn the bluetooth on the output device off, then back on. Search for earbuds and follow manufacturer procedures to sync earbuds. Once found, pair. Ensure when a successful pair happens that they are paired for phone and music. It will tell you on the output device if the pair was successful for both. At this point make sure your volume settings are not muted or all the way down and you should be enjoying music if you have an app playing music.
Posted on Feb 17, 2020
5 Related Answers
Anonymous
SOURCE: jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have [email protected] service and it works just fine. Hope this helps out!
Posted on Feb 08, 2009
Anonymous
SOURCE: bluetooth "device out of range or powered off"
I had lots of trouble too. I thought it was my phone. Well here's what you do. First off remove the device completely from your phone. Turn off the phone and take the battery off so it can re-boot. When the phone is powered back up put your bluetooth in pairing mode and get it back on your phone. It should connect without any problems. Now....here is the trick. When you want to disconnect the device(bluetooth) from your phone don't turn it off on your phone. Shut the actual power off on your bluetooth. The phone will recognize this and disconnect the device. The only thing left on your phone will be the bluetooth icon. Being the icon still on your phone it is still in discovery mode and can overtime use up your battery life searching for a device. This is when you can go to your phone and turn off the bluetooth. On your NV 2 go to your bluetooth menu and just use your left softkeyto turn it off. Now there is no connection whatsoever. And to turn it back on do the opposite. Go to your bluetooth menu and turn on your bluetooth. You will see the bluetooth icon. Now you power up the bluetooth and it will connect as soon as it get the signal. This took me 2 weeks of trial and error and other stuff but I am happy now and I hope this solves any bluetooth problems...
Posted on Jun 06, 2009
Anonymous
SOURCE: How do I connect my Sony Bluetooth headset DR BT21G to my Vaio
I solved this problem by turning off my phone which had bluetooth active while i was trying to get audio through. thats why the bluetooth never connected to my headset as the phone was using up the bandwith.
make sure your headset is the only bluetooth device and then go into your bluetooth properties -> audio -> select your headset and press connect
now go into your sound options and it should be listed there if it connected succesfully. set if as default and remember to restart the music programm youre running
enjoy!!! =D
Posted on Jun 25, 2009
Anonymous
  • 10 Answers
SOURCE: how to find my passkey on my HP Integrated Module
Passkey is 0000
Posted on Sep 21, 2009
Anonymous
SOURCE: my bluetooth wont connect to other devices
I cant connect with any other phone
Posted on Jan 11, 2010
Hello. OK, I have a wireless earbud paired to a windows 10 Professional PC. But I can't select it for output. It does not appear on the popup list of devices. How do it fix this?
Do the earbuds have a driver?
What audio card are you using?
Have you updated both the software and the firmware?
If you say "Paired" it sounds like you mean Bluetooth, rather
than "WiFi".
Which one are you talking about?
Aug 24, 2018 | The Computers & Internet
My tzumi wireless Bluetooth earbuds didn't come with instructions
  • Perfect appearance ,in-ear noise cancelling headphones are handcrafted from real wood;
  • The earphones have crisp powerful sound and strong deep bass;
Chornic Genuine Wood In ear Noise isolating Headphones Earbuds Earphones...
May 02, 2016 | Radio Communications
Where do I find the model number
The words "red and blue lights", "paired", "connect" and "beeps" make me believe that your headphones are Bluetooth-enabled. However, I never heard of a TV that is Bluetooth-enabled. Therefore, I do not think that you will be able to pair, nor connect your headphones to your TV. If you want to listen to your TV wirelessly, you will have to use regular (not Bluetooth) wireless headphones, which consist of two pieces: the headphones and a transmitter that connects to the audio output(s) of your TV and transmits the sound from your TV to the headphones wirelessly.
Dec 06, 2014 | iHip Audio Players & Recorders
How can I get my player to connest to my bluetooth headphones have tried several times no luck
If you have a Kindle Fire or later this is possible. Any Kindle before this model has the hardware for BT, but not any method to access the BT (bad on Amazon\'s part, but that\'s the way it is).
Kindle Fire do this: Go to settings --> Wireless --> Bluetooth Turn on Bluetooth if it is not on.
Now on your headset put it in pairing mode. Instructions on how to do this should have come with your headset. Once in pairing mode press Pair a Bluetooth Device on your Kindle. Your Kindle should "see" your headset and list the name of it under PAIRED DEVICES.
You only need to pair the device once. Then you should be able to press the device name and if the device is near by and on it should connect to the Kindle.
HTH
Jul 31, 2014 | iLive IHB603B Micro Bluetooth Stereo...
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Jan 28, 2014 | Dell Vostro Computers & Internet
Wireless bluetooth won't connect to phone
May not be compatable with ur phone check the internet site for the bluetooth to see if its compatable.
Nov 22, 2013 | Plantronics Discovery 640E Wireless...
I can not hear anything out of my right ear bud
Hi there thobe47!
Please test the pair with a different audio device and see if the problem goes away first!
Firstly, make sure you are pressing the plug all the way into your audio device jack. Most are designed with two tiers, so only one ear will sound if only one tier of the electrical connection is fully established. Once you've tried that, continue!
Most earbuds are created with very small working parts with equally small electrical connections. If you have lost sound in one side, the most likely cause is a loose connection somewhere.
If it still doesn't work, your options are sort of limited. I would recommend first gently "jimmying" the wire leading to the bad earbud around while it is in your ear and music is playing. If you manage to get the sound to be restored, wrap sticky tape tightly around the wire and the tapered part of the bottom of the earbud in an attempt to maintain the new connection. It is not a permanent fix but might buy you a bit of time with the pair.
If you can't get it to work in that way, your remaining options are pretty much to either open the earbud and attempt to reestablish the connection (difficult, small parts, and could damage the earbuds if you don't know what you are doing), or to buy a new pair. You can get some pretty nice earbuds for under $5 at most megastores, and anybody who could fix them and would charge you will charge you much more.
If you must try to open the earbud (I don't recommend it!), I have a generic set of steps here. I take no responsibility for damage of your earbuds or devices that may follow!
Gently peel back the gelly cover of the earbud, starting under the top seam and pulling it off.
Unscrew or "pop off" the portion of the earbud that has the small grating. There may be an inner retaining system involving more plastic rings. Just keep these safe and remember the order in which you took them apart.
You will now probably be seeing the speaker of the earbud, looking like what you might see on an uncovered subwoofer speaker (just much smaller!)
Being careful to not touch the flat portion of this disk and avoiding anything magnetic (including your laptop / desktop), see if you can pinch it by the sides and gently pull it out of the casing -- probably less than a quarter centimeter. If you can, look for any severed connections between the solder points on the bottom of the speaker and the wires coming from the bottom of the bud. Soldering these would be extremely difficult, but you can attempt to fix them with small pieces of tape.
Nestle the speaker back into the housing, replace any retaining disks in the correct order, screw/pop the outer clip back on, and slide the gelly back into place.
Hope this helps!
Mar 24, 2011 | JVC Gumy Ear Bud Headphone - Peppermint...
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
I replaced my phone and now i cant pair my plantronics explorer 233 it can't locate the device help me please
Hold down round button on earbud for 5-6 seconds until it flashes alternating red and blue. Then set your device (Phone/PDa) up for connectivity by allowing it to be discovered...Once your phone is in discovery mode, it will search and hpefully find the earbud. Then you may have to enter a connect code (usually 0000) for the pairing to enable. Once they are paired....enjoy!!
Jun 11, 2009 | Plantronics Explorer 220 Bluetooth Headset...
My bluetooth pairs but won't connect
Hello krissylucas,
Erase the Bluetooth Headset's name from the bluetooth pair devices list on the phone .. and reset the bluetooth headset then try to connect again
Thank you for using FixYa.
Apr 09, 2009 | Eforcity Motorola Bluetooth Headset H500...
Radio Communications Logo
103 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
