Question about Simpson Washing Machines
I have a Simpson Eziset 9.5kg top loader washing machine & the lint filter has dislodged & gotten jammed in the tube of the agitator. I can't get it back out. Please help
Posted by Tracey Armour on
ray gallant
    Top Expert:
  • Simpson Master
  • 68,634 Answers
WE CAN NOT HELP
Posted on Jul 17, 2020
5 Related Answers
Anonymous
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
Anonymous
  • 3 Answers
SOURCE: Whirlpool top loader washing machine - agitator does not turn
If it does not drain, I'd check the water pump first (for an obstruction - I found a sock in my pump and that fixed my problem) ... see this video - the top is getting to the WM drive shaft (transmission), but it shows you how to remove the pump first: http://www.youtube.com/watch?v=WLPGs2UMUJc&feature=related
If it does drain ... Is it just the TOP part of the agitator not working, or the whole thing (agitator is in 2 parts)? If just the TOP, you probably just need new "dogs" (agitator dogs). Check this out:
http://www.youtube.com/watch?v=V5wIN1J70-Y ... it shows you what to do.
If it is the whole agitator that is stuck, that video will show you how to remove it (remove a single bolt) and you can see if there is an obstruction keep the agitator from moving.
If there's no obstruction or the water pump isn't stuck, you might be looking at a new drive/transmission = expensive. Good luck
Posted on Jul 02, 2009
john_cross
  • 6277 Answers
SOURCE: i have a simpson eziset
There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor. Sorry but both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Posted on Mar 22, 2011
luisa_sgro
  • 713 Answers
SOURCE: I have a 3 yr
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
Posted on May 15, 2011
john_cross
  • 6277 Answers
SOURCE: Hi guys... I've a Simpson eziset 450 top load
As far as I am aware most washers have a filter, top loaders tend to be at the back, bad design in my opinion!
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 04, 2011
Testimonial: "I try this solution - thanks heaps"
Simpson washing machine
you need a 10mm socket and some extensions and a ratchet take the fabric softer filter out and undo the ,bolt at the bottom of the agitator and lift out
May 28, 2017 | Simpson Washing Machines
Simpson Eziset 750 top loader washing machine won't fill with water.
might be the inlet valve has failed or the main controller
Dec 03, 2016 | Simpson Washing Machines
I have a silk blouse caught under the agitator of my Simpson eziset 8.5kg top load washer. does the agitator come off?
They should come off though I am not sure of your machine, they are designed to be changed.
Mar 05, 2016 | Simpson Washing Machines
Where is the lint filter on a Simpson Eziset 950 top loader washer?
lint filters for simpons top loader is at the bottom of the center lift out piece in the agitator
just pull the lot up and the lint filter is a small pocket at the end of it
Dec 10, 2015 | Simpson Washing Machines
Where does the lint filter attach to on the Simpson 550 top loader?
the center of the agitator right at the bottom of the center which just pulls up
where the softener goes in. that section lifts out
Sep 10, 2015 | Simpson Washing Machines
Where does the washing detergent go in a Simpson eziset 550 washer
Bleach goes in the left hand side portal softener is put in top of agitator an washing powder I normally dissolve at start when machine filling before putting items in
Feb 23, 2015 | Simpson Washing Machines
How to fix error E17 code on eziset 9.5 kg top loader
Supply problem.
Check to see if water hose is plugged and test water pressure.Check water valve supply shut off.
See if filter is plugged.
Run full cycle w/no clothes in washer. Add 1 cup of vinegar,no soap.
May 03, 2014 | Washing Machines
Simpson error code 5p
I have a error code Ld come up on my Simpson eziset 5.5 kg top loader washing machine what does that mean ? Also is it possible to replace a sensor battery for that. Model and what size battery replacement do I need to ask for
Feb 23, 2011 | Electrolux Washing Machines
I have a Simpson EZI Loader 5.5kg, where is the lint filter
HI just read your posting.Now the SIMPSON EZI LOADER comes in front and top loader versions.Which type is yours?Are you getting a lot of lint on your clothes?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 03, 2010 | Washing Machines
Hi I have a simpson eziset 605 washing machine and it has stopped spinning.. I have checked the belt and thats seems fine the washing machine just wont spin.. if anyone has any idea of what it could be...
Hi Carlee just read your posting.Now the Simpson Eziset machines come in top and front loader versions.Which type is yours?Please reply with this additional information and I will help you rectify this fault.
Washing Machines Logo
120 people viewed this question
Top Simpson Washing Machines Experts
STEVE SPAM REMOVER
j_woodman
Level 1 Expert
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
