Question about The Kitchen Appliances - Others
About an hour after cooking a 8 lb prime rib,While the rotisserie is rotating it falls on to the drip pan. Would not rotate without falling. Ended up finishing the roast in the oven . Your thoughts?
Posted by Dan Roux on
5 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: how long to cook 22 lb turkey at 325 degrees
4 hours with stuffing 4.5
Posted on Dec 18, 2007
ellenskitche
  • 62 Answers
SOURCE: Lost instruction manual
http://www.rivalproducts.com/manuals/MANUALS/RO188BR_43_81844057.PDF
That is the URL for the manual. I find their recommended temperatures tend to run about 25 degrees hot; be sure you check the internal temp with a quick read thermometer starting 15-20 minutes before it "should" be done.
Posted on Nov 26, 2009
Anonymous
SOURCE: I need the farberware rotisserie manual suggested
All Farberware Rotisserie Manuals are available for download at http://openhearth.info. The manual that has the prime rib recipe is http://openhearth.info/450.htm . However, I have tried this recipe, and if cooked according to those instructions, the prime rib will be overdone. I take mine off at a much lower temperature to allow for carry-over cooking. These rotisseries make the BEST prime rib!
Posted on Dec 24, 2009
Anonymous
SOURCE: Self cleaning attempt has shut down the control panel.
You need an air flow kit, part 81911788 and a professional to install it.
Posted on Jan 09, 2010
chester chester
  • 51 Answers
SOURCE: how to cook a boneless beef prime rib roast
just make a cut along the rib and then pull the bone
Posted on Dec 08, 2012
How to cook with electric smoker How to cook a brisket? Do you place directly on grate or do you place in a pan
I have found that when using my electric smoker and cooking ribs or brisket I use the gadget that you can purchase that puts your food on end thereby exposing all the meat surface to smoke.The item I use I made myself but similar racks can be puchased. I would not use a pan at any time , if nothing else place directly on a rack.
Happy Smoking !
Sep 17, 2017 | Grilling
My ribs came out done but not fall off the bone tender. What cAn I do to achieve fall off the bone tender?
For pork ribs, start by cooking them for 2 hours, at 225, internal temp 160 degrees, then remove from the cooker and foil them.
Be sure to put some of your mop juice, or apple juice inside the foil packets to help them steam and get tender.
Smoke them in in the foil for about 1:45 to 2 more hours. Remove the ribs carefully and vent them. They will be fall apart tender now, and fragile. Let them sit.
After about 10 minutes they will have firmed up again enough to move them back onto the grill for glazing. Use some sauce or a finishing rub to taste.
Feb 16, 2015 | Grilling
I have all new burner element, starter and thermometer,,,because I had a MAJOR fire from deteriorating fire unit Now I used grill to rotisserie a chicken, cleaned everything and when using it to grill...
When you cooked the chicken on the rotisserie, did you remove the cooking grates and place a disposable drip pan on the flame tamers below the chicken? This will prevent the grease from dripping down into the bottom of the grill when you use the rotisserie. The bottom of the unit needs to be kept clean so the grease will run to the drip pan and not get caught in the bottom of the unit. When you are done cooking, if you will close the lid and turn the grill on high for 10 to 15 minutes it will help to burn off any grease build up and prevent fires in the future.
Jun 11, 2011 | Dynasty DBQ-30 (LP) Grill
Cooking Time
Google "Smokering" and you will find a lot of forums dedicated to smoking food. It is an art in itself but many of these forums are helpful in learning.
The answer to your question is basically put as many racks of ribs that fit without touching and as long as the temperature is maintained they will all cook at the same time. I typically smoke my ribs at 225 for 4-5 hours.
May 24, 2010 | Masterbuilt 20050106 Propane Smoker
How do I smoke pork ribs in the char-broil gas smoker? How long to smoke ribs and at what tempeture?
use a drip pan with some water or apple juice, they should cook approx. 2 1/2 hours at 325.
Feb 20, 2010 | Char-Broil CharBroil 4637318 Grill
Dec 23, 2009 | Farberware FRA10ST 10-Cup Rice Cooker
Nov 24, 2009 | Rival 18 Qt Roaster Oven with Buffet...
Too big of a turkey
I LOVE these roasters!!! And now you've made me hungry for turkey. Yum!!! ;)
You shouldn't have a problem cooking your big bird in that roaster. You may have a little trouble getting it ALL to fit in at first, but of course, the turkey will shrink a bit as it cooks and it'll all fall into place. When you're stuffing Tom (the bird...Not the guy) into the roaster, you may have to coerce the cover to fully close over the top, but it shouldn't be too much of an issue. I've cooked even larger birds in my Rival 18qt without any issues, other than some that I mentioned above.
I hope this helps and have a very Happy Thanksgiving! :)
Nov 13, 2009 | Rival 18 Qt Roaster Oven with Buffet...
How to use Rotisserie?
GE has the instruction manual online at: http://www.gehousewares.com/products/countop_oven_rotise_1066410585855.pdf
Make sure you look at the cook times. The manual suggests using a separate timer (I use my regular oven's timer if I'm not cooking anything with that at the time) I've been reading a lot of negative feedback about this product but I love mine and use it regularly.
Nov 21, 2007 | GE 168947 Toaster Oven with Convection...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
