SOURCE: MY b60 all of a sudden won't fill a full cup when
When I descaled my b60 I also used a paper clip to clean out a possibe clog in the little bottom drainage tube. The help I received suggested I also use the paper clip to check the top tube which I didn't know about. I did this and now it works fine...thanks for your help.
SOURCE: why would water spew out while using My kcup in
The top gasket is not sealing on the endention of the my k cup. Open the handle look inside around the top needle and there will be a black gasket around it. Pull it down just a little so that it makes better contact with the My K Cup.
SOURCE: part that holds kcup is broken need replacement
your talking about the kcup holder?
i know of a great site
http://stores.ilikenew.com
it sells replacement keurig parts
SOURCE: Keurig B60. Brand New used maybe 4 Kcups. Now
if water does go thru it...try white vinagar/water mixture about 1/2 cup vinagar to full tank water..
run cycles until empty...NO Kcups..then run full tank of clean water.....
SOURCE: My kcup brewer leaks water
I had the same problem I bought a 1/2" rubber washer and duct taped it to the top of the reusable unit and it has been working great for about a month, the indent in the reusable filter is too far away from the brew section of the machine
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
