Question about Lands Phones
My new landline phone won't work with condo intercom like old phone did
Posted by Judy Sakundiak on
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: AT&T 974 phone intercom button flashing and won't work
1) test the adapter if working with another phone and replace it
2) if working clean the contacts batteries with pencil eraser, and see if working.
3)test the batteries voltage is o.k wit VOM, and replace if necessary
4) test the power supply from the base if is o.k otherwise you must open and repair or go to the repair shop for fix it.
5) Read the owner manual section troubleshooting for help
God bless you
Posted on Sep 18, 2012
How do I forward my phone number on a Dect 6.0 cordless phone model 30524
Do you mean the GE DECT 6.0 30524 corded/cordless phone? For this landline telephone, you can switch a call from one handset to another (or the base) by using the Intercom feature. Press del/int on the handset or Int on the base and choose a handset number (use the CID +/ phonebook -) buttons (if multiple handsets are registered) or select base from the handset. Press Menu/OK to page the other handset or base. Once that device answers the incoming Intercom call, press and hold Del/Int or Int to create a conference call (both handsets or handset and base listening). Press Del/Int or Int to switch from the Intercom call back to the call on hold. Hang up on the first handset if the person on the second handset will continue to speak to the original caller alone. See pages 24-25 of the manual to see the directions. The direct link to the manual is currently https://www.101phones.com/pdf/ge/30524-user-guide-english-f.pdf .
For any landline phone, to forward a call to another phone number, you need to subscribe to a forwarding option with your telephone company. Check their information for initiating call forwarding.
If you have a different 30524 phone, please add a comment with the manufacturer.
I hope this helps.
Jun 27, 2018 | Dect Lands Phones
Landline phone constant busy signal
should you dial 9 or another access code for outside calls?
If if you dial an "outside" number on an intercom line it will look at the first 2-3 digits as another extension. You need to dial the Central Office access code, or use a line key assigned to an outside line.
Jan 17, 2014 | NorStar Lands Phones
Novi doorbell intercom system won't work. Got it about 8 years ago, worked OK except for minor problems until recently. Now it malfunctions constantly. We finally had to disconnect the wiring o
If you are looking for new intercom system then I would suggest you to buy it from http://www.hulksecurity.com/ .Hulk Security System not only provides intercom systems but they also offer variety of access control system, CCTV and alarm systems. Well, I hope this would help you and have sorted the concern for intercom system.
Oct 24, 2012 | Novi Wireless Doorbell Intercom Security...
God bless you
Sep 17, 2012 | Lands Phones
How do i switch from intercom to telephone?
If you unplug your phone and plug it back in, perhaps that will work for you. Ours always flashes when we do that but if you have a cell phone, just call your landline and it should return to normal. Hope that works.
Nov 19, 2011 | Lands Phones
How to use the intercom system
  • Check your telephone to see if it has an intercom feature. Many wireless phones that come with multiple units allow you to temporarily turn one unit into an intercom to contact other units attached to the same wireless phone system. Depending on the model, you can contact all the other phones at once, or a single specific phone, by pushing the intercom button and entering the other mode. To put the phone back into regular mode, all you have to do is switch off the intercom option.
  • Contact your telephone provider. Some telephone service providers allow landline phones to call themselves, which enables the phone to function as an improvised intercom. You would simply pick up the phone, dial and then close the connection. Once the phone is answered elsewhere in the house, you will have established a line to another phone and you can speak normally on it. This has largely been eliminated due to lack of need as technology advances, but it may still be an option with some providers.
  • Purchase and install an intercom system that will work through an existing phone line. Many of these products, some of which are produced by Panasonic, operate as a halfway point between a traditional intercom system and a phone line. The exterior intercom links directly to the phone line, and you can pick up the phone and talk through the intercom unit outside once the system is properly set up
  • Dec 18, 2010 | Uniden Cordless Phone
    Talkin between two parallel phones
    Simple. Press 161 on one phone set. After you hear the beeps, put the receiver down. You'll hear both phone sets ring. Now you can pick up your receiver and the person on the other floor can pick up the receiver there, and you can talk. There is no cost involved.
    __ L.R. Hegde
    Jun 21, 2009 | Lands Phones
    Lands Phones Logo
    87 people viewed this question
    Top Lands Phones Experts
    Marvin
    Marvin
    k24674
    Are you a Lands Phone Expert? Answer questions, earn points and help others
