Defy Twinmaid 1300. When in spinning mode the drum vibrates with a screeching noise. Had a coupling replaced 8 months back. How can I do the replacement
Posted by Percy Bedser on
Andrew Taylor
    Top Expert:
  • Washing Mach... Master
  • 33,301 Answers
Made in China, it seems to be badged to different companies.
This looks similar
SERVICE MANUAL
www.premiumus.com > download > model=service_manual_PWM60...
PDF Can not wash (motor does not rotate). 3.22. Spin tub can not rotate. 3.23. No drain or unsmooth drain. 4.Dismantling ways of main parts. 4.1. Remove the knobs.
Defy Twinmaid 1300 Washing Machine - Manual
manuall.co.uk > ... > Washing Machines > Defy Washing Machines
If this is not the manual you want, please contact us. Is your product defective and the manual offers no solution? Go to a Repair Caf? for free repair services.
Replace a coupler
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00Ll6NcobkEe1RmEcR3EBjfiMbquA%3A1595003189431&ei=NdERX77kGfvDytMPqcOx4A0&q=defy+twinmaid+1300+replace+coupling
Posted on Jul 17, 2020
5 Related Answers
Ronnie Houston
  • 2920 Answers
SOURCE: Frigidaire (LTF2940) Front Load Washer Makes
the belt is either loose or off the drum or the tensioner gave out...please rate me thank you
Posted on Aug 10, 2008
Anonymous
SOURCE: Noise on spin mode fast loud clanking like something in drum
Wow, we're having a similar problem vibrating like crazy...just online to try and figure it out..
Posted on Dec 29, 2008
Anonymous
SOURCE: loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Posted on Apr 21, 2009
Anonymous
  • 225 Answers
SOURCE: loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
Posted on May 02, 2009
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: Screeching on spin. Kenmore 110.92284100
The spin clutch/brake assembly has failed; you must remove the agitator, tubs, bottom seal. then remove the transmission from the bottom; the spin clutch/ brake assembly is located around the transmission agitator shaft under the tub. not a job for the faint of heart; difficult fix; most people just replace the machine. an appliance parts store can get you the part and, give you instructions in replacement procedure if you wish to do this repair.
Posted on Apr 07, 2010
Testimonial: "Quick to diagnose and respond. Thanks!"
My defy twinmaid 1300 machine worked suddenly smell luje burn and swirch off now machine dont wanna go in
Nees to be taken apart and see what caused the burnt smell and look for a blown fuse.
Mar 02, 2018 | Washing Machines
Defy twinmaid 800 spinner rotate very slow
Wiring diagram for a defy Twinmaid 800 washing machiine?
howtomendit.com > Household Appliances, Washing Machines Free repair help - wiring diagram defy twinmaid 800 washing machiine. ... machine spins very very slow sometimes and sometimes it doesn't spin help please.
Jul 24, 2015 | Washing Machines
My defy twinmaid spiner dont want to spin what can be the problem
If it makes a humming sound it's belt , if not it might water level pressure switch, and if the knob on timmer dose'nt advance its the timmer.
Feb 24, 2015 | Miscellaneous
How do i fix the spinners knob of the defy 1000 twinmaid washing machine
Write your answer...i have a twinmaid 1000 defy.The problem is the spinner.When i turn the timer on,it makes the sound but it does not spin.What could be the problem?
Jan 10, 2015 | Washing Machines
Defy Laundromaid 1300 making grinding noise while washing,how do i remove pulsator to see if there is something in it
if the grinding noise is more pronounced at spin cycle , it could be the drum it self, if the grinding noise is there constantly, could be the bearing to the drum. front loader. easy to fix, let me know..
Apr 14, 2014 | Washing Machines
How can i remove the spinner drum from a defy twinmaid 920 (twin tub)? please help?
1)You have to tip the machine on it's back and remove all the screws from the bottom grey cover.
2)There are 4 screws securing the drain plug at the back. Remove these as well. Gently pry off the bottom of the machine.
3)The spin motor sits on four spring mounts. Undo the 4 screws from the top of the mounting plate.The motor shaft is not screwed to the drum. Slide the motor out of the drum shaft.
4) Once free, there are 2 X 10 mm bolts that lock in 2 grub screws on the shaft. Loosen these an remove the grub screws and remove this coupling off the drum shaft.
The drum is now free to come out the top of the machine.
Hope this helps
Jun 16, 2012 | Washing Machines
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
Big Thunk when Frigidarie Front Loading washing machine started the final spin cycle, then at the end of the cycle soft screeching sound when drum is moving back and forth, any thoughts? [email protected]
does not sound good. if you can remove a cover on front bottom or on the back you may find a broken shock, or counter weight, either would need replacing before running again
Jan 08, 2012 | Washing Machines
Defy automaid won't spin
Put the machine on its side and check the wires to the pump. i found one of the wires broke off the lug on the pump side. Could be from all the vibration from the drum. The machine will only spin if the drainage is working.
Good luck.
Mar 10, 2009 | Washing Machines
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
