Question about Samsung Refrigerators
Have a samsung fridge ice maker keeps frezing up
Posted by Linda Raguso on
Jorgie Navito
    Master:
  • Samsung Master
  • 357 Answers
Ice Maker Doesn't Turn Off
If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removingand replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
http://www.appliancerepair.net/refrigerator-repair-1.html
Ice Maker Is Frozen Up
This ice maker repair is even easier. If your ice maker has frozen up, take the following steps to thaw it out:
1Unplug the refrigerator.Remove the ice bin from the refrigerator and remove any loose ice from the ice maker.
2Find the fill tube.This isawhiterubber-like hose that delivers water to the ice maker. Pull down the small metal clip off the housing that holds the fill tube (though not all ice makers have this clip).
3Warm the hoseand surrounding mechanism. To do this, you can train a hair dryer on the ice maker to melt any ice blocking the mechanism. But be very careful (sop up any dripping water with a rag) as electricity and water can present a serious risk of electrical shock. Also, be careful not to melt the plastic parts.
4If you don't want to use a hair dryer,you can soak the supply tubing with hot water, using a turkeybasterand catching the overflow in the empty ice maker bin. In some cases, it may be easier to remove the ice maker than to thaw out the fill tube.
On heat release ice makers You will want to check the heating element within the ice maker for continuity and a visual inspection of the board and conductors for burns and seizing,charedmarks.
How to Test the Ice Mold Heater
There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver. Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. It is easier to work on this type of unit by first removing the entireicemakerfrom the freezer compartment. The unit is usually mounted to the freezer case by two or more screws. Remove the bottom screws first. While supporting the ice maker, remove the remaining top screws. Unplug the ice maker from the freezer cabinet if you have not already done so.Along the edge nearest the shutoff arm, a pin protrudes through the mounting plate. The arm pin has a spring under the mounting plate. Reduce the tension on the spring by moving the shutoff arm into the "on" position, down, against the ice maker.
Test the heater for resistance using amultitester. Set themultitesterto the ohms setting X1. Touch one probe to each of the two terminals (or wires). The reading should be in the range of 60 to 90 ohms. If you get a significantly different reading, such as zero or infinity, then the mold heater is bad and needs to be replaced.Conduct this test with therefrigerator unplugged. Test the moldheaterfor resistance using amultitester. Set themultitesterto the ohms setting X1. Place one probe into the hole labeled "H" and the other probe into the hole labeled "L". Themultitestershould read in the range of 60 to 90 ohms.
Also be sure to check and test water valvewith a meter for continuity and voltage..( a full 120 and nothing less) And a visual inspection for any ice build up or blockage in tubing and flow line. Remember u may get a close circuit reading of continuity however it may still be bad in that it may remain constantly closed and water keeps flowing more than suppose to. Hence chunks of ice build up.
:God is the reason I give you free advice so God is good!
Posted on Mar 12, 2020
5 Related Answers
Anonymous
  • 883 Answers
SOURCE: Ice maker water level too high
generally, there is a screw adjustment for this. usually, turning it clockwise sends more water during fill period (makes period longer). try it and adjust clockwise or counter-clockwise as necessary. Now finding the screw...try prying (or unscrewing) off the plastic cover over what appears to be the ice-maker unit (may also be on back side of frig.
Posted on Sep 17, 2007
Anonymous
  • 3 Answers
SOURCE: Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Posted on Jan 14, 2009
Anonymous
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Posted on Mar 26, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Posted on Sep 09, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: icemaker 3 drawer fridge
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
bmbmm,b
Posted on Sep 30, 2010
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Panel board keeps flashing
I have a Samsung rf26xaewp side by side fridge that was built in 11/2009. On the front of ice maker the setting on the left is flashing 88. The setting on the right is bouncing between 88 an 89. I cleaned the back an looked at computer board, there is a red light on. Fridge feels like its thawing. Only thing ice maker will do is expense ice.
1helpful
Should I buy a Samsung 26 cu. ft. french door fridge with ice maker on top?
hey there, it depends on your budget and what fits in your kitchen, my self have a
Samsung RFG23UERS1 fridge and i am very happy with that one, so like i said its up to your budget and if it fits
Icemaker 3 drawer fridge
heatman101
bmbmm,b
Rs2556sh model leakes water under fridge when ice maker cycles
If there was water in the water line it could have split. Check on the back where the water line goes from the inlet valve to the ice maker.
2answers
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Our Samsung ice maker stopped working
Ice Maker Not Dispensing
I have fought with ice makers before and I find it to be easier when considering the time and trouble dedicated to troubleshooting and frustration of not having ice when you want it, to just replace the unit. You can purchase a replacement Ice maker for your fridge on-line for $85.00 plus shipping and handling. At the most you will have to remove 3 screws and unplug one electrical connection (please remember to unplug your fridge before attempting replacement) and your ice troubles will be over.
1helpful
2answers
Water constantly runing to ice maker/ over flowing ice tray
Flow level has to be clean, or remplace.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/fredis_44a2b9c16ffcde8e
Samsung fridge rb215 bottom freezer ice maker
On most samsung Refrigerator ice makers there will be a button on it to test the functionality of the ice maker. Its a small button covered with clear rubber. When you locate it hold that down for 10 to 15 seconds and if it is functional it should run through its paces. Is it the ice maker in the left fridge door , the freezer compartment, or the one inside the fridge to the left?
Refrigerators Logo
Top Samsung Refrigerators Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
