Question about Teac Audio Players & Recorders
I have a TEAC AG-V3020 Surround Receiver.Replaced the CD player PD-D850.Trying to connect it to the receiver and I can only hear a low sound and the speakers crackle and pop.Any ideas of what it is?
5 Suggested Answers
kenvid
SOURCE: receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Posted on Dec 13, 2007
Anonymous
  • 5 Answers
SOURCE: Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Posted on Jan 07, 2008
Anonymous
SOURCE: Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Posted on Mar 10, 2008
Anonymous
SOURCE: Pioneer Multichannel Receiver VSX-D508 (including cd player & tape deck)
receiver on the screen displaying power off
Posted on Apr 15, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Receiver keeps flashing "PROTECT"
The protect message indicates that a problem was detected in the last stage of the amplifier and that it has shutdown to prevent further damage. Usually this indicates that the output transistors have failed. Any shop that works on audio should be able to repair this. Expect a part cost in the $20-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Dec 17, 2008
My Teac AG-V3020 makes clicking relay sound when attempting to power up.
recheck your connections it appears that something is cross if so recorrect the connections on your system
Nov 29, 2014 | Teac Audio Players & Recorders
No sound from receiver
is the test tone loud or at the same level. you need to check the volume level of your player dvd, cd to make sure it's all the way up some players have volume level built into them.
Apr 12, 2014 | Audio Players & Recorders
We dont have the manual for our TEAK AGV 1200 RECEIVER AND I NEED TO KNOW HOW MANY WATTS IT HAS? Any way I can find out with the manual?
You have to type alpha-numeric gibberish verbatim or there will be no good information coming back.
If you mean TEAC AG-V1200 then just google it.
Here's a manual for $10 http://www.teac.owner-manuals.com/AGV1200-owners-manual-TEAC.html
It probably has the specs.
This seller claims 110 watts per channel all around, which sounds supsiciously generous. Rear channels don't need that kind of horsepower.
http://cgi.ebay.com/Teac-AG-V1200-Dolby-Surround-Receiver-Remote-/250828929416
Aug 04, 2011 | Teac AG-780 2 Channels Receiver
Lost manual..do not know what is the difference sound surround
Hi use this link to download the manual .
manualnguide.com/manual/teac-ag-v8060-receiver.../page/2/.
Take care.
May 18, 2010 | Teac AG-V8060 Receiver
Surround Sound won't go on. Connected and setup all speakers. Did the speakers test. And playing a DVD surround sound won't go on.
You don't say what the DVD model is and how it's connected. What DOES work? Is surround not working for other sources, too? Have you connected the DVD player to other inputs to see if the problem is in it or the receiver? Is the digital input on the receiver assigned to the DVD player? You have some homework to do.
Jan 19, 2010 | Teac AG-D8900 Receiver
NO SOUND
Check speaker terminal connections, then source input, then surround mode choice.
Dec 12, 2007 | Teac AG-D8900 Receiver
Setting Up The System
You can find the requested details at: http://www.teac.com.au/file/product_manual_408.pdf
Mar 09, 2006 | Teac AG-D8900 Receiver
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
