SOURCE: Dirt Devil vacuum
You might unhook the belt, if it still sounds real loud, then the motor is bad and will have to replaced.
Posted on Jan 06, 2008
SOURCE: Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Posted on Apr 08, 2009
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Posted on Apr 29, 2009
SOURCE: dirt devil dynamite spinning thing isn't spinning
does the unit have a belt?
Posted on Feb 01, 2010
SOURCE: How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
Posted on Mar 08, 2010
May 09, 2016 | Vacuums
Jan 01, 2016 | Dirt Devil Vacuums
Sep 30, 2014 | Dirt Devil Vacuums
Jul 14, 2014 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Jun 06, 2017 | Royal Dirt Devil BD10050 Scorpion...
Jan 29, 2011 | Dirt Devil M086700 Vision Bagless Upright...
Nov 06, 2009 | Vacuums
Nov 29, 2008 | Royal 5300 Upright Vacuum
Sep 01, 2008 | Dirt Devil Deluxe Handheld Vacuum
Jun 03, 2008 | Dirt Devil M088300 Upright Vacuum
93 people viewed this question
