Question about The Office Equipment & Supplies
My original 39AS seems to have no coloring in the lettering is this normal ?
Posted by Jim Burns on
Not Me
  • The Master
  • 3,157 Answers
Please give us more details including what the brand and type of machine it is that you are asking about. Probably not a Marlin 39AS rifle.
Posted on Jul 19, 2020
Normal color print ,black print cuts off top/bottom of letters
Suggest using the printer software utility to clean the print heads, then print a test page.
Nov 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
Cant figure out color issue with computer.
Well...it's a Dell and even when it's well...it's still a Dell.
Have you tried the monitor on different system to eliminate the tower being the problem? Some have updated and/or rolled back drivers to help cure this problem, which seems to be a common issue with this LCD. Personally i think the contrast ratio is inadequate.
Good luck with your Delllll...
May 14, 2009 | Dell E176FP 17" LCD Monitor
I have a 42 flat screen projector. The picture i see doulbe the normal color of the letter. then behind the letter they show up in different color. Then when there people on the screen or object there...
The colors have to be aligned most systems have a calibration screen with in the setup menu
Follow the instructions .... this is a common issue
LB
Sep 21, 2008 | Televison & Video
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
47 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Bruce Showalter
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
