Water Heaters Logo
C
Carl Christopher Kopp Posted on Dec 31, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My whirlpool gas water heater model N50T61-403 has gone out. I have tried restarting it 3 times per the manufacturers instructions. Any idea what the problem is.
Dennis
Level 3:
Top Expert:
  • Master 1,057 Answers
  • Posted on Dec 31, 2019
Dennis
Master
Level 3:
Top Expert:
Answers
1057
Questions
Helped
441047
Points
13558
My first suspect is the thermocouple has failed (they should be changed periodically, every 5-7 years as they do fail). Without the signal from the thermocouple, the gas valve can not open and start the ignition process.
5 Related Answers
Anonymous
  • Posted on Apr 22, 2009
SOURCE: Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Anonymous
  • 332 Answers
  • Posted on Jun 27, 2009
SOURCE: My GE gas fired water heater pilot goes out after
you will need to change the thermal coupling,, when it is lit look at it and make sure there is no water dripping down on it, but for now it just sounds like the thermocoupling
Anonymous
  • 101 Answers
  • Posted on Sep 13, 2009
SOURCE: Electronic ignition tries to lite, clicks 5 times, then goes POOF
Gas burners go "poof" when they have too much gas in the area upon lighting. This is normally due to the ignition source not being close enough to the initial source of gas. This is normaally corrected by ensure the main burner is clean so that it distributes the gas correctly and having the ignition source at proper strength and location. I would have to have good schematics of your heater to be more specific. I hope this helps.
HANK MCNEIL
  • 252 Answers
  • Posted on Oct 23, 2009
SOURCE: I have a Rheem glas fury model 22-40 gas water - leaking
once they leak it's time for a new water heater. ther is no way to repair a tank leak
jdthefixer
  • 747 Answers
  • Posted on Dec 31, 2009
SOURCE: pilot light on water heater goes out frequently
Check the following:
See if your heater has a pilot gas adjustment valve. It should be on the gas control valve somewhere. Not all heaters have these. It will be a screw on the valve that can be turned.
Make sure the thermocouple sensing bulb is squarely in the pilot flame and also check that the fitting where the other end of the thermocouple connects to the main gas valve is tight.
Check the pilot gas orifice (where the pilot gas comes out) for carbon build up - you may need to remove the pilot gas line and thermocouple assembly to get to this. This problem is pretty common.
Check the gas pressure to the heater. Run the hot water in the dwelling until the hot water heater starts. Check the flame on the main burner and see what color it is - it should be blue with possibly some yellow-tipped flames. If not, there could be a problem with the gas pressure at the heater or venting. If the heater has a gas pressure regulator, it may be out of adjustment or defective.
Finally, and this isn't very common, the pilot light can be extinguished if there is a draft problem, usually associated with an issue with the flue pipe venting system for the heater or another nearby gas consuming appliance.
Testimonial: "thank you. will try these suggestions tomorrow. really appreciate it."
Where can I get the new sensor unit for Whirlpool water heater (N40S61-403)?
1) Call whirlpool
1-877-817-6750
Need model and serial number located on label on side of tank
2) Copy following links for troubleshoot and repair resources, including service manual by type of gas control valve.
http://waterheatertimer.org/How-to-replace-thermocouple.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Get parts sheet from manual that arrived with new product.
4) Otherwise, neither Whitlpool or Craftmaster.has up-to-date product manual, parts sheet, or service manual, rendering their sites near useless for many owners.
Whirlpool site has 'troubleshoot and repair' section, but this is NO help for serious DIY repair.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Replace thermocouple gas water heater
Thank you for the brand. Approx how old is water heater? 2nd and 3rd digit of serial number are year of manufacture.
For general instructions:
Reliance is AO Smith, and air intake is located on bottom of tank.
Inspect and Clean intake.
Do NOT underestimate need to keep air intake clean because the arrestor screen is fine mesh and once clogged will cause heater to fail. Older models might need full replacement and at least parts.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
Product manual?
These gas water heaters are changing quickly today. The Reliance site shows the 909 but not 805
http://www.reliancewaterheaters.com/lit/om.html
The older designs are different, but instructions shown above will help.
FV sense code
Type of gas control valve is not known.
Brand of water heater is not known.
FV event can mean that air intake is clogged, gas control valve has gone bad, or FV system has tripped, or TCO has tripped ... or all of above.
Clean air intake, download manual from manufacturer and read troubleshoot section, call manufacturer.
Copy following links for troubleshoot resources
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
I am looking for a manuel for a whirlpool hot water heater model number fg1f3030s3pv. I tried to contact sears direct but they did not have one for that model. They told me to try going onto...
1) Whirlpool is a good water heater. Add a comment any time and describe the water heater gas control valve and other features for best possible resources. Many of the new Whirlpool gas heaters arrive with Honeywell electronic gas valve.
2) Web search for fg1f3030s3pv water heater turns up generic gas water heater manual showing dial-type gas valve, piezo igniter, with good section on parts and repairs, and a troubleshoot checklist:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0603477.pdf
3) Whirlpool is made by American water heater, Oct 2011.
Open following links for more manuals.
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
http://www.americanwaterheater.com/support/manuals.aspx
4) If you are trying to fix the water heater and want other resources.
Also add a comment with specific description of problem and what you have done so far:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Whirlpool-Resettable-ECO-20.jpg
5) Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
We have a bradford defender model # MI403S6FBN7. How do we reset it. lost manual
Water heaters are a huge field of knowledge. Problem is not 100% clear.
There is a resettable thermal switch on the combustion door. This switch is round and has two wires that come from gas control valve. Thermal switch trips when combustion parts have not been cleaned and they cause overheated condition, or sensor reads temperatures above 180, or thermal switch has gone bad, or gas control has gone bad.
http://waterheatertimer.org/images/Whirlpool-Resettable-ECO-8.jpg
Add a comment with more information for continued help.
1) Bradford White support:
http://www.bradfordwhite.com/supportserv.asp
2) Bradford white mi403s6fbn is 6-year-warranty 40 gallon tank-type gas water heater with Icon electronic gas valve, and atmospheric venting.
Older models have the dial-type Robert Shaw or White Rodgers gas valve.
Open following link to see age of Bradford White:
http://www.bradfordwhite.com/findaserial.asp
3) Bradford white has 'product manuals' and 'service manuals' on following link:
Product manuals have general information and advisories that people can read about water heaters.
Service manuals are for plumbers and technicians, and do-it-yourselfers for testing and repairing water heaters.
http://www.bradfordwhite.com/documentation/residential/gas.asp
4) Typical manual for your product shows different gas valves, lighting instructions, and advisories, and troubleshoot checklist:
http://www.bradfordwhite.com/images/shared/pdfs/manuals/238-44219-00J.pdf
5) Add a comment with following information if you want specific help with servicing water heater.
What are you trying to reset on the water heater?
What are the symptoms, and what have you noticed, and what have you tried so far?
Which gas valve does your water heater have? Please open typical manual and view images of the three basic gas valves.
When was water heater last serviced and cleaned?
How old is water heater?
Take a moment and rate answer:
I have a whirlpool water heater mod. Fg1f4034t3nv. Igniter will not work'.instructions missing. Have all lines. Etc disconected how do I get assembly out?
I don't know because I can't see it, and I don't have manual.
But I can give you resources:
Call Whirlpool:
(877) 817-6750
Whirlpool is usually Craftmaster which is American which is AO Smith.
http://www.hotwater.com/water-heaters/residential/conventional/gas/
Age of water heater shows on serial number: first two digits should be year, second two digits should be week.
The market is always changing.
Find manufacturer using label on side of tank, find manual with parts diagram, and order burner parts. Whirlppol site does not have manuals.
http://waterheatertimer.org/Water-heater-manufacturers.html
It might be cheaper to install a new water heater yourself from box store for $330.00
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
Pilot will not stay light but will turn on and work properly
When having a problem with pilot and burner, the place to start is troubleshoot section in your manual.
Whirlpool is probably made by Craftmaster which I believe is a Rheem company, and Rheem makes a number of different models.
Some models have specific manuals and others have generic manuals.
Open Rheem water heater page and click on water that matches your water heater. On page that opens, click on tab that says 'specs' and then download manual.
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
If none of those water heaters look like yours, open following link to help identify company website and download manual. Craftmaster website does not have instruction manuals.
All gas water heaters require periodic maintenance.
Some require yearly maintenance.
The burner parts require cleaning.
http://waterheatertimer.org/images/Clean-burner-300.jpg
http://waterheatertimer.org/images/Clean-burner-250.jpg
1helpful
2answers
Can i convert a whirlpool water heater from propane to natural gas
I would recommend to contact the manufacturer. There are certain model of water heaters that cannot be converted at all. The technical support line can answer your question on this. Please have your model, product, and serial number when calling 1-877-817-6750.
Top Whirlpool Water Heaters Experts
Paul Carew
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
