Question about Whirlpool Dishwashers
Whirlpool dishwasher does not consistently function in the ECO mode only.
Posted by John Shas on
ray gallant
    Top Expert:
  • Whirlpool Master
  • 68,634 Answers
THEN DON'T USE THAT MODE
Posted on Jul 20, 2020
2 Related Answers
Anonymous
SOURCE: won't come out of eco mode
if the receiver is on, you can press the "Eco" Button and then, you have to rotate the "Multi-Joy" in the next 3 seconds to change Eco-Mode to Off. When you selected it, you have to confirm with enter.
Posted on Jan 09, 2009
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: whirlpool adg 155 eco button flashes
see this causes and use the common sense. God bless you
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check for 120 volt at the power box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi limit fuse.
Door Switch
This is the second place to look. Again an inexpensive easy fix. The following video will walk you thru checking the door switch. The power comes into the main power box and usually runs to the door switch next before entering the main control module.
Main Control Module / Timer
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the control module, this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor. Make sure the motor is recieving power.
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace. We have video and tutorials that cover several styles.
Posted on Sep 20, 2012
My whirlpool quiet partner II imperial series Dishwasher will only work on light wash mode. Normal wash, heavy wash or pots and pans cycle will not work at all.
This is ordinarily a problem with the touchpad. Can you give me the specific model number of yours (ordinarily on a sticker on the inside edge of the door or on the door opening)?
Mar 06, 2016 | Whirlpool Dishwashers
The time on now shows 107 instead of 127 min. drawer Fisher & Pakel double
your dishdrawer is in ECO mode. Press the ECO button on the program panel on top of drawer lid. This should restore the Heavy wash time to 127min.
Mar 29, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
What is eco light
Eco light means the dishwasher has change to hybrid mode which is an energy saver.
Apr 05, 2012 | Kenmore Dishwashers
The drying function doesn't appear to be working
If water remains on the dishes after washing even when you select the normal wash modes (not ECO) then the air dryer fan is faulty assuming the water heater is working.
May 14, 2011 | Fisher and Paykel 24 in. DS-603 Built-in...
Why is my dishwasher flashing on the eco 45 button
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Unknown 2007 Toyota Camry Hybrid Button
The ECO HEAT/COOL button of your hybrid functions to reduce the consumption of electricity thus, a reduction of fuel consumption. An indicator 'ECO' appears on the air conditioning display to indicate that the mode is on. Of course, with the ECO HEAT/COOL on it'll take longer than the usual amount of time for the temperature to reach its normal or standard set temperature.
Your ECO HEAT/COOL mode won't function if your temperature control is set at 'LO" or 'HI" or if the air flow is in the "floor/windshield mode" or "windshield mode".
Hope this helps.
-jay
Jul 03, 2009 | 2007 Toyota Camry
Won't come out of eco mode
Aug 13, 2008 | Aiwa AV-D58 Receiver
Dishlex global 300 dishwasher, eco light flashing sounds like pump noise but not working
Try taking the dishwasher out of its wall space and tipping it back and forth. Apparently the weight of water gathering in some component triggers the 'eco' function. Failing that, last time it happened to my dishwasher i waited a week for the repair guy to arrive, by which time the water had evaporated and there was no longer a problem..
Jul 26, 2008 | Dishwashers
Whirlpool inbuil dishwasher
likely a logic board.
the fact that it goes from start to finish without any 'event' suggests that the board is bad.
good luck
mark
Aug 29, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
105 people viewed this question
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
