Question about Teac Audio Players & Recorders
My teac 4110 won't play when i push play but will fast in both directions?
gopakumarg43
  • 76237 Answers
SOURCE: Teac A170S won't play, RW, FF, or record.
Hello
Can you hear the motor running, when you press any of the Play, Rew or FF buttons?. Just place your ear very close to the player and listen to it. If the answer is 'yes', the drive belt is broken or slipped off. You have to replace the drive belt. If the answer is 'no' the motor of your device's drive mechanism has damaged, and should be replaced. OK.
WISH YOU A PROSPEROUS 2012.
Gopakumar G, Kerala State, South India.
Posted on Dec 26, 2011
My reel to reel will not play.
You need a new capstan belt or the capstan shaft is glazed as well as you have a hard shiny Pinch Roller. Each of these items need to have friction to work.
Nov 19, 2013 | Teac Audio Players & Recorders
TEAC R-H300 Forward Play Fault
The unit need some work by a technician. The bad thing about the drawer type decks is that it makes it hard or impossible to clean the tape path. I have not seen one of these but I could probably fix it.
Some of your description sound like a loose capstan belt and then other times the Pinch roller is not engaging- they may be related if the mechanism is tied to the capstan motor system.
Sep 11, 2012 | Teac R-H300 Dual Cassette Deck
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
I Press Play Button, And Tape Goes Into Fast Forward Mode
Pinch Roller linkage is stuck. Clean and regrease and it will work right again- I have done hundreds of them
May 01, 2012 | Teac Audio Players & Recorders
I have a Teac A-6300 that won't go fast forward or reverse but the capstan motor is running
The Capstan motor is just for the play speed regulation so it has nothing to do with the reel motors. You can have an open safety microswitch or maybe a bad relay. It is really hard to say without looking at the unit but I am sure it is repairable. Is the right dummy plug put in the back? This can stop all transport functions if it is out.
Apr 14, 2012 | Teac Audio Players & Recorders
Teac HDR2500T Fast Forward/Rewind problem: It
easy, download the software update from the teac website- had the same problem myself
Jan 10, 2010 | Televison & Video
My PVR a TEAC HDR1600T is jumping with recived singnal.
the hard disk gets very very hot, I suggest you switch it off when not in use and reformat once in a while. I think the cpu (some motorola or something) isn't particularly fast as it can only handle so much at the same time as well.
Jul 12, 2009 | Televison & Video
How to start to play
Go here for a picture:
http://www.proaux.com/TEAC-A4010-GSL-Reel-to-Reel-Recorder,name,1638,auction_id,auction_details
http://www.angelfire.com/electronic2/vintagetx/index.html
The two arrow buttons on either side of the FAST key will play it Forward or Reverse. Combining the FAST key with a direction initiates a fast forward or rewind.
May 16, 2009 | Teac GF-600 Turntable
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
32 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
